[postgis-users] Problems installing PostGIS on Red Hat EL 5
Jeshua Lacock jeshua at 3DTOPO.com
Tue Apr 1 22:48:31 PDT 2008
On Apr 1, 2008, at 11:39 PM, Paragon Corporation wrote:
> /usr/lib/pgsql/liblwgeom.so: undefined symbol:
> GEOSTopologyPreserveSimplify
> CONTEXT:  SQL statement "SELECT postgis_lib_version()"
> PL/pgSQL function "postgis_full_version" line 11 at SQL statement
> When I run
> select postgis_full_version()
> (or any postgis function for that matter)
Hi Regina,
Looks like PostGIS needs to be linked against the Geos library.
When you run configure use the "--with-geos=" directive, and point it
to the full path of where "geos-config" is located. For example, if
geos is installed to /usr/local, the configure option might look
something like this:
	--with-geos=/usr/local/bin/geos-config
Hope this helps.
Regards,
Jeshua Lacock
Founder/Programmer
3DTOPO Incorporated
<http://3DTOPO.com>
Phone: 877.240.1364
