[postgis-users] can't find lwlgeom
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Tue Apr 29 02:51:12 PDT 2008
Hi Chris,
> I've been googling around the web, and my problem appears to be fairly
> common.. although I haven't seen a good explanation for it.. I've
> installed PG 8.3.1.. and postgis.
> Looks like everything installs correctly.. when I run make check, I get
> the (somewhat common) can't load share lib $libdir/
> psql:lwpostgis.sql:44: NOTICE: type "histogram2d" is not yet defined
> DETAIL: Creating a shell type definition.
> psql:lwpostgis.sql:44: ERROR: could not access file
> "$libdir/liblwgeom.so.1": No such file or directory
> **NOTE: when I run ldconfig -v liblwgeom.so.1 shows up.. but the
> original error was "$libdir/liblwgeom" not found.. I actually modified
> lwpostgis.sql to use liblwgeom.so.1 What should it be ?
lwpostgis.sql was fine it its original form using $libdir (it get
substituted by PostgreSQL with the correct server library directory at
load time).
> This error seems common enough that there would be a pretty simple
> explanation for it.. how I can be sure that the libraries were built
> correctly?
> Kind of stumped right now.. not really clear what it's supposed to be.
> ANY help would be appreciated.. thanks
If liblwgeom.so exists, this error normally means that liblwgeom can't
find one or more of its dependent libraries such as GEOS and/or PROJ.4.
Check your ld.so.conf to make sure it includes /usr/local/lib if you
built by hand, and then don't forget to restart the PostgreSQL server so
it can pick up the changes.
HTH,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
