[postgis-users] can't find lwlgeom
Chris mollis
cmollis at objectlab.com
Tue Apr 29 07:09:57 PDT 2008
Hi Mark-
Thanks for responding to this issue. I was able to get around this
issue by modifying the lwpostgis.sql file and replacing the $libdir var
with the fully qualified path name to the shared object. I ran all of
the tests successfully. I guess this proves that the $libdir variable
isn't being set correctly with postgresql, even though PG_CONFIG reports
it to be set (note I stopped and restart the server a few times during
this process). I believe there is a function exported by postgresql db
that allows me to set this variable, but I haven't tried it. Anyway,
seems to be working now..
thanks
Chris
Mark Cave-Ayland wrote:
> Hi Chris,
>> I've been googling around the web, and my problem appears to be
>> fairly common.. although I haven't seen a good explanation for it..
>> I've installed PG 8.3.1.. and postgis.
>> Looks like everything installs correctly.. when I run make check, I
>> get the (somewhat common) can't load share lib $libdir/
>> psql:lwpostgis.sql:44: NOTICE: type "histogram2d" is not yet defined
>> DETAIL: Creating a shell type definition.
>> psql:lwpostgis.sql:44: ERROR: could not access file
>> "$libdir/liblwgeom.so.1": No such file or directory
>> **NOTE: when I run ldconfig -v liblwgeom.so.1 shows up.. but the
>> original error was "$libdir/liblwgeom" not found.. I actually
>> modified lwpostgis.sql to use liblwgeom.so.1 What should it be ?
> lwpostgis.sql was fine it its original form using $libdir (it get
> substituted by PostgreSQL with the correct server library directory at
> load time).
>> This error seems common enough that there would be a pretty simple
>> explanation for it.. how I can be sure that the libraries were
>> built correctly?
>> Kind of stumped right now.. not really clear what it's supposed to
>> be. ANY help would be appreciated.. thanks
> If liblwgeom.so exists, this error normally means that liblwgeom can't
> find one or more of its dependent libraries such as GEOS and/or
> PROJ.4. Check your ld.so.conf to make sure it includes /usr/local/lib
> if you built by hand, and then don't forget to restart the PostgreSQL
> server so it can pick up the changes.
> HTH,
> Mark.
