[postgis-users] can't find lwlgeom
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Tue Apr 29 07:23:14 PDT 2008
Chris mollis wrote:
> Hi Mark-
> Thanks for responding to this issue. I was able to get around this
> issue by modifying the lwpostgis.sql file and replacing the $libdir var
> with the fully qualified path name to the shared object. I ran all of
> the tests successfully. I guess this proves that the $libdir variable
> isn't being set correctly with postgresql, even though PG_CONFIG reports
> it to be set (note I stopped and restart the server a few times during
> this process). I believe there is a function exported by postgresql db
> that allows me to set this variable, but I haven't tried it. Anyway,
> seems to be working now..
> thanks
> Chris
No problem. The only other time I've seen this is if you accidentally
have multiple versions of PostgreSQL installed on a server (one from
packages and one compiled by hand), and PostGIS has been configured
using --with-pgsql to point to the wrong one (and hence the library is
installed into the wrong $libdir).
Of course, all of this also assumes that SELinux has been disabled too ;)
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
