[postgis-users] Get concave hull from an array of longitude in latitude points
Martin Davis
mbdavis at refractions.net
Wed Dec 3 09:46:26 PST 2008
You might also check out this paper:
http://www.foss4g.org/index.php/foss4g/2008/paper/view/226/157
It uses a "connect-buffer-simplify" approach.
Martin Davis wrote:
> I think the ideas for the solution have already been posted on this
> thread - you either need to use alpha shapes or one of the concave
> hull algorithms. It sounded like pgrouting has an alpha shapes
> implementation - that would probably be the easiest way forward.
> Implementing the other algorithms would be non-trivial.
> It might also help if you posted a picture of what you think the
> desired output should be, for the sample data you posted.
> Aleš Kecman wrote:
>> Hi!
>> I'm still struggling with this "concave hulls" and it seems I just
>> can't find the way how to do it. I'm sending a text file with some
>> longitude and latitude points of selected subarea from which I need
>> to get a concave polygon. There is only one polygon in attached text
>> file. In my database I have around 500 000 points from which I need
>> to form around 700 polygons. If there is a way to do it in PostGis I
>> would really appreciate any help. I also attached a jpg picture of my
>> convexhull polygon. Thanks!!!
>> Greets, Ales.
>> On Mon, Nov 24, 2008 at 12:13 PM, Mark Cave-Ayland
>> <mark.cave-ayland at siriusit.co.uk
>> <mailto:mark.cave-ayland at siriusit.co.uk>> wrote:
>> Aleš Kecman wrote:
>> Hi!
>> I'm new to Postgis and would really like to get some help on
>> getting a concave hull from an array of points.
>> For example:
>> I have an array of points - longitude and latitude of
>> buildings in particular area in the city. I already managed to
>> get a convex hull polygon from this array of points, but this
>> is not really helpful. What I'm trying to get is some kind of
>> concave hull polygon from an array of points, which I would
>> further like to use in Google Earth kml file.
>> Thanks.
>> Hi Aleš,
>> Does ST_Union() help you at all?
>> ATB,
>> Mark.
>> -- Mark Cave-Ayland
>> Sirius Corporation - The Open Source Experts
>> http://www.siriusit.co.uk
>> T: +44 870 608 0063
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> <mailto:postgis-users at postgis.refractions.net>
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
