[postgis-users] Get concave hull from an array of longitude in latitude points
Martin Davis
mbdavis at refractions.net
Wed Dec 3 09:09:05 PST 2008
I think the ideas for the solution have already been posted on this
thread - you either need to use alpha shapes or one of the concave hull
algorithms. It sounded like pgrouting has an alpha shapes
implementation - that would probably be the easiest way forward.
Implementing the other algorithms would be non-trivial.
It might also help if you posted a picture of what you think the desired
output should be, for the sample data you posted.
Aleš Kecman wrote:
> Hi!
> I'm still struggling with this "concave hulls" and it seems I just
> can't find the way how to do it. I'm sending a text file with some
> longitude and latitude points of selected subarea from which I need to
> get a concave polygon. There is only one polygon in attached text
> file. In my database I have around 500 000 points from which I need to
> form around 700 polygons. If there is a way to do it in PostGis I
> would really appreciate any help. I also attached a jpg picture of my
> convexhull polygon. Thanks!!!
> Greets, Ales.
> On Mon, Nov 24, 2008 at 12:13 PM, Mark Cave-Ayland
> <mark.cave-ayland at siriusit.co.uk
> <mailto:mark.cave-ayland at siriusit.co.uk>> wrote:
> Aleš Kecman wrote:
> Hi!
> I'm new to Postgis and would really like to get some help on
> getting a concave hull from an array of points.
> For example:
> I have an array of points - longitude and latitude of
> buildings in particular area in the city. I already managed to
> get a convex hull polygon from this array of points, but this
> is not really helpful. What I'm trying to get is some kind of
> concave hull polygon from an array of points, which I would
> further like to use in Google Earth kml file.
> Thanks.
> Hi Aleš,
> Does ST_Union() help you at all?
> ATB,
> Mark.
> Mark Cave-Ayland
> Sirius Corporation - The Open Source Experts
> http://www.siriusit.co.uk
> T: +44 870 608 0063
> postgis-users mailing list
> <mailto:postgis-users at postgis.refractions.net>
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
