[postgis-users] problems cleaning geometry - other options?
William Kyngesburye woklist at kyngchaos.com
Wed Dec 3 16:08:45 PST 2008
I'm trying to fix some polygons-with-holes imported from shapefiles
where the main polygon is not the first in the list, one of the hole
polygons is, making them invalid.
These are 3D multipolygons - imported from the SRTM SWBD shapefiles
(with GDAL). (file w162n55n if anyone wants to try)
The cleanGeometry funtion at:
http://postgis.refractions.net/support/wiki/index.php?CleanPolygons
isn't working, I get an error:
=>select astext(cleangeometry(wkb_geometry)) from swbd where cell =
145018 and wb = 353;
NOTICE:  Hole lies outside shell at or near point -161.201 55.9992 0
CONTEXT:  PL/pgSQL function "cleangeometry" line 15 at IF
ERROR:  Dimensions mismatch in lwcurve
CONTEXT:  PL/pgSQL function "cleangeometry" line 19 at assignment
I tried forcing the geometry to 2D (st_force_2d()) and I get a
different error:
ERROR:  Exception in LWGEOM2GEOS: curved geometry not supported.
These shapefiles don't have curved geometry (I'm not sure it's
supported in shapefiles).
I wonder if there is a simpler operation that could reorder sub-
polygons to put the one that contains all the others first?  And would
it be faster or slower?
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an
illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
