[postgis-users] problems cleaning geometry - other options?
Kevin Neufeld
kneufeld at refractions.net
Wed Dec 3 23:02:02 PST 2008
Have you tried updating the geometry with a new polygonized polygon
constructed from the linework?
UPDATE swbd
SET wkb_geometry = ST_BuildArea(ST_Boundary(wkb_geometry))
WHERE cell = 145018 AND wb = 353;
Cheers,
-- Kevin
William Kyngesburye wrote:
> I'm trying to fix some polygons-with-holes imported from shapefiles
> where the main polygon is not the first in the list, one of the hole
> polygons is, making them invalid.
> These are 3D multipolygons - imported from the SRTM SWBD shapefiles
> (with GDAL). (file w162n55n if anyone wants to try)
> The cleanGeometry funtion at:
> http://postgis.refractions.net/support/wiki/index.php?CleanPolygons
> isn't working, I get an error:
> =>select astext(cleangeometry(wkb_geometry)) from swbd where cell =
> 145018 and wb = 353;
> NOTICE: Hole lies outside shell at or near point -161.201 55.9992 0
> CONTEXT: PL/pgSQL function "cleangeometry" line 15 at IF
> ERROR: Dimensions mismatch in lwcurve
> CONTEXT: PL/pgSQL function "cleangeometry" line 19 at assignment
> I tried forcing the geometry to 2D (st_force_2d()) and I get a
> different error:
> ERROR: Exception in LWGEOM2GEOS: curved geometry not supported.
> These shapefiles don't have curved geometry (I'm not sure it's
> supported in shapefiles).
> I wonder if there is a simpler operation that could reorder
> sub-polygons to put the one that contains all the others first? And
> would it be faster or slower?
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "History is an illusion caused by the passage of time, and time is an
> illusion caused by the passage of history."
> - Hitchhiker's Guide to the Galaxy
> postgis-users mailing list
