[postgis-users] Multi centroids
Mike Toews
mwtoews at sfu.ca
Fri Dec 5 15:07:47 PST 2008
Hi Kevin,
That was exactly what I was after, thanks! Here is my modified function
which I've tested to some degree with MULTIPOLYGONs only:
CREATE OR REPLACE FUNCTION ST_MultiCentroid(geometry)
RETURNS geometry AS
$BODY$SELECT ST_Collect(the_geom)
FROM (
SELECT ST_Centroid((ST_Dump($1)).geom) AS the_geom
) AS foo;$BODY$
LANGUAGE 'sql' IMMUTABLE
COST 100;
-Mike
Kevin Neufeld wrote:
> Yes. Use ST_Dump to explode your MULTI* object, take the ST_Centroid
> of each, and ST_Collect them together again.
> SELECT ST_AsText(ST_Collect(the_geom))
> FROM (
> SELECT ST_Centroid((ST_Dump(the_geom)).geom) AS the_geom
> FROM (
> SELECT
> 'MULTIPOLYGON (
> (( 0 0, 0 1, 1 1, 1 0, 0 0 )),
> (( 2 2, 2 3, 3 3, 3 2, 2 2 ))
> )'::geometry AS the_geom
> ) AS foo
> ) AS foo2;
> st_astext
> MULTIPOINT(0.5 0.5,2.5 2.5)
> (1 row)
> Cheers,
> Kevin
