[postgis-users] Multi centroids
Kevin Neufeld
kneufeld at refractions.net
Fri Dec 5 15:48:25 PST 2008
Very nice Mike. I added your function to the wiki here:
http://postgis.refractions.net/support/wiki/index.php?ComputeMultiCentroid
I don't see why it won't make it into PostGIS some time ... seems like something useful.
Cheers,
Kevin
Mike Toews wrote:
> Hi Kevin,
> That was exactly what I was after, thanks! Here is my modified function
> which I've tested to some degree with MULTIPOLYGONs only:
> CREATE OR REPLACE FUNCTION ST_MultiCentroid(geometry)
> RETURNS geometry AS
> $BODY$SELECT ST_Collect(the_geom)
> FROM (
> SELECT ST_Centroid((ST_Dump($1)).geom) AS the_geom
> ) AS foo;$BODY$
> LANGUAGE 'sql' IMMUTABLE
> COST 100;
> -Mike
> Kevin Neufeld wrote:
>> Yes. Use ST_Dump to explode your MULTI* object, take the ST_Centroid
>> of each, and ST_Collect them together again.
>> SELECT ST_AsText(ST_Collect(the_geom))
>> FROM (
>> SELECT ST_Centroid((ST_Dump(the_geom)).geom) AS the_geom
>> FROM (
>> SELECT
>> 'MULTIPOLYGON (
>> (( 0 0, 0 1, 1 1, 1 0, 0 0 )),
>> (( 2 2, 2 3, 3 3, 3 2, 2 2 ))
>> )'::geometry AS the_geom
>> ) AS foo
>> ) AS foo2;
>> st_astext
>> MULTIPOINT(0.5 0.5,2.5 2.5)
>> (1 row)
>> Cheers,
>> Kevin
> postgis-users mailing list
