[postgis-users] Optimizing DATA queries
Pavel Iacovlev iacovlev.pavel at gmail.com
Thu Dec 11 09:13:23 PST 2008
Good day all
At the moment I use the following logic for LINES::
I have the pixel width and pixel height in meters and I check if the
perimeter of the geometry bbox is greater then the pixel perimeter, on each
MAP request.
POLYGONS:
st_simplify and check if the geom perimeter is greater then a pixel on map ?
POINTS
Only 1 point in X radius, any example for such a query ?
Can you share any other ways to reduce the INPUT data to mapserver taking in
consideration you know the scale ?
http://iap.md, The future is open
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081211/02aba6ac/attachment.html>
