[postgis-users] Changed bahaviour of PostGIS confuses MapServer
Peter Hopfgartner
peter.hopfgartner at r3-gis.com
Fri Dec 12 05:25:15 PST 2008
Dear MLs,
sorry for cross-posting to both, PostGIS and MS, but seems to rtouch both.
I've tried to install PostGIS 1.3.4 on a CentOS 5 server with MapServer
5.2.1 and PostgreSQL 8.2.11.
the command:
shp2img -l prova -e 1587541 5116731 1591730 5120008 -m prova.map >
../../public/technet/test-<pgis-version>.png
with 1.3.3 gave the result shown in figure test-postgis-1.3.3-4.png (a
simple line layer)
Upgrading to 1.3.4 the picture became as in test-postgis-1.3.4-1.png, an
empty picture.
The relevant mapfile fragment is Mapfile.frag.txt, the SQL table
definition is e405.sql, all objects are MULTILINESTRINGs [SELECT
DISTINCT geometrytype(the_geom) FROM public.e405 results in
MULTILINESTRING], the geometry column is registered as MULTILINESTRING
in geometry_columns.
Running the MapServer query:
SELECT
asbinary(force_collection(force_2d(the_geom)),'NDR'),common_uid::text
from public.e405 WHERE (tiplinapp is not null) and (the_geom && setSRID(
'BOX3D(1587541 5116702.44897959,1591730
5120036.55102041)'::BOX3D,find_srid('','public.e405','the_geom') ))
changed for better result readability into:
SELECT AsEWKT(force_collection(force_2d(the_geom))),common_uid::text
by hand gives slightly different results, as shown in the attached files.
To make a long story short, 1.3.4 seems to better preserve the
MULTILINESTRING, but this seems to confuse MapServer.
Regards,
Peter
Dott. Peter Hopfgartner
R3 GIS Srl - GmbH
Via Johann Kravogl-Str. 2
I-39012 Meran/Merano (BZ)
Email: peter.hopfgartner at r3-gis.com
Tel. : +39 0473 494949
Fax : +39 0473 069902
www : http://www.r3-gis.com
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081212/aed76e3e/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081212/aed76e3e/attachment-0001.png>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081212/aed76e3e/attachment.txt>
Type: text/x-sql
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081212/aed76e3e/attachment.bin>
Type: text/csv
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081212/aed76e3e/attachment.csv>
Type: text/csv
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081212/aed76e3e/attachment-0001.csv>
Type: text/csv
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081212/aed76e3e/attachment-0002.csv>
Type: text/csv
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081212/aed76e3e/attachment-0003.csv>
