[postgis-users] NAD conversion problem
Frank Warmerdam
warmerdam at pobox.com
Thu Dec 11 11:11:31 PST 2008
Peter N. Schweitzer wrote:
> Dylan Beaudette wrote:
>> Looks close to the output from proj4 above.
>> Thoughts?
> Dylan,
> Thanks for showing me how to check the calculations. I get identical
> results using my copies of cs2cs and postgis, on both systems.
> I conclude from this that the effect of adding @null to the definition
> of NAD27 in pj_datums.c is that it somehow eliminates the error message
> but doesn't render the results incorrect. I don't pretend to understand
> why this is so, but I'm happy to proceed with this configuration.
Peter,
Adding @null to the end essentially means that if all else fails, just
apply a null transformation and don't complain if the null file isn't
found.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
