[postgis-users] Crossing roads
Paul Ramsey
pramsey at cleverelephant.ca
Sat Dec 13 16:30:35 PST 2008
Stop thinking lines and start thinking endpoints. If you convert your
lines into a set of start/end points then group on x/y you'll end up
an aggregation which defines your sets of road intersections.
If you want until Monday, I bet Kevin or Regina will drop full SQL
into your lap. I'm too lazy (stupid).
P.
2008/12/13 Andrew Ross <rummage_bin at yahoo.com>:
> Hi Everybody,
> I hope I'm posting to the right location (I just subscribed to this list).
> I have sent this question before but have not seen it listed anywhere yet.
> In any case, I have a road network in which all of the street segments are
> snapped together. I need to group all of the line segments of two streets
> that cross each other (street 1 and street 2 as shown below) into 4 groups
> of segments defined as all of those located on either side of the
> intersection, (street segments A, street segments B, street segments C and
> street segments D, as shown at the bottom).
> Can anybody give me a high level idea of what functions / methods can be
> used to achieve this?
> I've gotten as far as identifying the 4 segments actually connected to the
> intersection using the ST_Intersection function.
> How would I get all other segments connected to these 4?
> Do I have to write a recursive function using ST_Touches ? I'd rather not
> if there is a more elegant way of doing this.
> Thanks in advance,
> Andrew
> 1
> 1
> 1
> 1
> 222222222222 X 22222222222222
> 1
> 1
> 1
> 1
> A
> A
> A
> A
> BBBBBBBBBBXCCCCCCCCCCC
> D
> D
> D
> D
> ________________________________
> postgis-users mailing list
