[postgis-users] get data from 2 tables and 2 columns fro second table
lisek lichu
lisek.lichu at gmail.com
Sun Dec 14 12:20:52 PST 2008
hello i have simple problem but I'm new in SQL so I will as here :P
i have 2 tables
CREATE TABLE points (
id SERIAL PRIMARY KEY
SELECT AddGeometryColumn('','points','the_geom','4326','POINT',2);
CREATE TABLE edges (
id SERIAL PRIMARY KEY,
start_point_id INTEGER REFERENCES points (id) ON DELETE RESTRICT ON
UPDATE CASCADE,
final_point_id INTEGER REFERENCES points (id) ON DELETE RESTRICT ON
UPDATE CASCADE
and right now I want to write a query to get in one line id from edges, and
two geometrical points (start and final)
something like this:
select e.id, AsText(p.the_geom) as start, AsText(p.the_geom) as final
from edges as e,points as p
where ???
and I dont knoe how to write thi query to get in one line edge ID and two
Can somebody help me with that?
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081214/e94359fe/attachment.html>
