[postgis-users] Re: get data from 2 tables and 2 columns fro second table
lisek lichu
lisek.lichu at gmail.com
Sun Dec 14 12:36:25 PST 2008
Ok i think i have resolved this problem :P
select e.id, AsText(p1.the_geom) as start, AsText(p2.the_geom) as final
from edges as e,
points as p1,
points as p2
where e.start_point_id = p1.id and e.final_point_id = p2.id;
after that i get what i want :)
if somebody has better solution for that it would be really great to share
it with me :P
On Sun, Dec 14, 2008 at 21:20, lisek lichu <lisek.lichu at gmail.com> wrote:
> hello i have simple problem but I'm new in SQL so I will as here :P
> i have 2 tables
> CREATE TABLE points (
> id SERIAL PRIMARY KEY
> SELECT AddGeometryColumn('','points','the_geom','4326','POINT',2);
> CREATE TABLE edges (
> id SERIAL PRIMARY KEY,
> start_point_id INTEGER REFERENCES points (id) ON DELETE RESTRICT ON
> UPDATE CASCADE,
> final_point_id INTEGER REFERENCES points (id) ON DELETE RESTRICT ON
> UPDATE CASCADE
> and right now I want to write a query to get in one line id from edges, and
> two geometrical points (start and final)
> something like this:
> select e.id, AsText(p.the_geom) as start, AsText(p.the_geom) as final
> from edges as e,points as p
> where ???
> and I dont knoe how to write thi query to get in one line edge ID and two
> Can somebody help me with that?
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081214/1ca13e9c/attachment.html>
