[postgis-users] pgsql2shp.exe fails with Windows Vista
Paragon Corporation
lr at pcorp.us
Tue Dec 16 18:54:51 PST 2008
I mean XP and 2000 boxes all works fine. Vista is broken for pgsql2shp but
works fine for psql and shp2pgsql.
It couldn't be some dumb thing like because I presume psql was compiled with
VC++ and pgsql2shp I presume was compiled with MingW? (all are stack builder
installs at anyrate)
-----Original Message-----
Sent: Tuesday, December 16, 2008 9:48 PM
To: 'PostGIS Users Discussion'
Subject: RE: [postgis-users] pgsql2shp.exe fails with Windows Vista
Mark,
I was running it with command line options to output the file.
Without options it works fine.
It gets as far as creating the .shp, .dbf, .shx before it crashes. All 3
files are pretty empty except some weird header gobbly gook so I guess its
when its getting into the loop to start reading the data so you could be
right about the libpq.
Though if libpq were the problem, wouldn't I have the same issue running
psql and psql works fine.
As a side note -- shp2pgsql works fine though that doesn't depend on libpq
anyway.
Not sure it matters, but I don't actually have PostgreSQL installed on my
Vista, so I'm just running from a folder with psql, pg_dump, libpq etc and
all the dependency files in the folder, which works perfectly fine on my XP
and Vista boxes.
Thanks,
Regina
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Mark
Cave-Ayland
Sent: Tuesday, December 16, 2008 7:08 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] pgsql2shp.exe fails with Windows Vista
Paragon Corporation wrote:
> Oops sent too quickly. Gives
> Unhandled exception at 0x76f8814c in pgsql2shp.exe: 0xC0000005: Access
> violation reading location 0x01ce2882.
> Unfortunately I'm not good at debugging c code. Mark does the above
> message mean anything to you.
Only that pgsql2shp is trying to do something that Vista doesn't like?
Could it be related to pgsql2shp trying to locate libpq.dll? I guess this is
just running pgsql2shp without any additional command line options?
> In VS 2008 - just tells me binary not built with debug info.
That's correct, the installer versions are stripped to remove the debug to
keep the sizes down. I have the original unstripped versions here, but I'm
fairly certain that gdb/MSVC have different debug info formats.
Hence if you want to debug, you'll need these unstripped versions and a copy
of MSYS/gdb on your Vista box to get a backtrace.
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts http://www.siriusit.co.uk
T: +44 870 608 0063
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
