[postgis-users] pgsql2shp.exe fails with Windows Vista
Dan Blomberg
services at gpsfiledepot.com
Tue Dec 16 19:13:05 PST 2008
I am running it with commands. This is what I'm running:
"c:\Program Files\PostgreSQL\8.3\bin>
pgsql2shp.exe -f contours.shp -u postgres postgis contours
Initializing... Done (postgis major version: 1).
Output shape: PolyLine
Dumping: X"
It crashes at the X and does exactly what Regina is saying (those three
files empty). The same command works fine on XP.
Dan
Paragon Corporation wrote:
> I mean XP and 2000 boxes all works fine. Vista is broken for pgsql2shp but
> works fine for psql and shp2pgsql.
> It couldn't be some dumb thing like because I presume psql was compiled with
> VC++ and pgsql2shp I presume was compiled with MingW? (all are stack builder
> installs at anyrate)
> -----Original Message-----
> From: Paragon Corporation [mailto:lr at pcorp.us]
> Sent: Tuesday, December 16, 2008 9:48 PM
> To: 'PostGIS Users Discussion'
> Subject: RE: [postgis-users] pgsql2shp.exe fails with Windows Vista
> Mark,
> I was running it with command line options to output the file.
> Without options it works fine.
> It gets as far as creating the .shp, .dbf, .shx before it crashes. All 3
> files are pretty empty except some weird header gobbly gook so I guess its
> when its getting into the loop to start reading the data so you could be
> right about the libpq.
> Though if libpq were the problem, wouldn't I have the same issue running
> psql and psql works fine.
> As a side note -- shp2pgsql works fine though that doesn't depend on libpq
> anyway.
> Not sure it matters, but I don't actually have PostgreSQL installed on my
> Vista, so I'm just running from a folder with psql, pg_dump, libpq etc and
> all the dependency files in the folder, which works perfectly fine on my XP
> and Vista boxes.
> Thanks,
> Regina
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Mark
> Cave-Ayland
> Sent: Tuesday, December 16, 2008 7:08 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] pgsql2shp.exe fails with Windows Vista
>> Oops sent too quickly. Gives
>> Unhandled exception at 0x76f8814c in pgsql2shp.exe: 0xC0000005: Access
>> violation reading location 0x01ce2882.
>> Unfortunately I'm not good at debugging c code. Mark does the above
>> message mean anything to you.
> Only that pgsql2shp is trying to do something that Vista doesn't like?
> Could it be related to pgsql2shp trying to locate libpq.dll? I guess this is
> just running pgsql2shp without any additional command line options?
>> In VS 2008 - just tells me binary not built with debug info.
> That's correct, the installer versions are stripped to remove the debug to
> keep the sizes down. I have the original unstripped versions here, but I'm
> fairly certain that gdb/MSVC have different debug info formats.
> Hence if you want to debug, you'll need these unstripped versions and a copy
> of MSYS/gdb on your Vista box to get a backtrace.
> ATB,
> Mark.
> Mark Cave-Ayland
> Sirius Corporation - The Open Source Experts http://www.siriusit.co.uk
> T: +44 870 608 0063
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081216/6e6ea22a/attachment.html>
