[postgis-users] Error in building postgis 1.3.5 from source
Obe, Regina
robe.dnd at cityofboston.gov
Thu Dec 18 09:18:04 PST 2008
Don,
Did you do a
make install
before you did the
make check
I think the docs were confusing in that regard, but I thought we fixed that.
The error you have below sounds like you probably compiled fine, but didn't install the binary.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net on behalf of Don Isgitt
Sent: Thu 12/18/2008 12:12 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Error in building postgis 1.3.5 from source
./configure was clean, but
in the make step of building postgis 1.3.5 from source, I am getting the
following error:
Creating spatial db postgis_reg
createlang: language "plpgsql" is already installed in database
"postgis_reg"
ERROR: function postgis_lib_version() does not exist
LINE 1: select postgis_lib_version()
HINT: No function matches the given name and argument types. You might need
to add explicit type casts.
Something went wrong (no postgis installed in postgis_reg).
For details, check /tmp/pgis_reg_20814/regress_log
This log shows the following error and then a bazillion "Current transaction
aborted...: messages.
BEGIN
psql:lwpostgis.sql:59: NOTICE: type "histogram2d" is not yet defined
DETAIL: Creating a shell type definition.
psql:lwpostgis.sql:59: ERROR: could not access file "$libdir/liblwgeom": No
such file or directory
I am running postgresql version 8.3.3 .
Any clues?
Thank you.
Don
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081218/33eab70a/attachment.html>
