[postgis-users] ST_AsKML changes in 1.3.3
Eduin Carrillo
yecarrillo at yahoo.com
Thu Dec 18 20:38:35 PST 2008
I apologize to arrive late to this discussion. I want to clear some things:
- As Google Earth only supports WGS84 projection, PROJ.4 is required to ensure correct transformation from any SRS to WGS84 This requisite is on lwgeom_kml.c but not in lwpostgis.sql.in.c. So users will see KML functions even if compiled without PROJ.4 support.
- _STAsKML is an internal function to wrap all AsKML calls before geometry is transformed into 4326. This function was previously called AsUKML ("u" for "unprojected") on first versions of my patch. Lately it was renamed to _STAsKML for compatybility with AsGML functions. Any call to _STAsKML(geom) returns pseudo KML with coordinates in native SRS, not useful in Google Earth.
Eduin Yesid Carrillo Vega
Ingeniero Civil, Universidad Industrial de Santander UIS
Laboratorio de Biogeografía y Análisis Espacial
Instituto de Investigación de Recursos Biológicos Alexander von Humboldt
yecarrillo at humboldt.org.co
Cr.13 28-01 P.7
Tel. (+57 1) 3506064 ext 122
Bogotá D.C., Colombia
----- Mensaje original ----
De: "Obe, Regina" <robe.dnd at cityofboston.gov>
Para: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Enviado: jueves, 20 de noviembre, 2008 7:47:28
Asunto: RE: [postgis-users] ST_AsKML changes in 1.3.3
Yah its worth a note. Guess that should be done for ST_Transform too.
Any other functions require Proj?
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Mark
Cave-Ayland
Sent: Wednesday, November 19, 2008 11:12 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] ST_AsKML changes in 1.3.3
Dylan Beaudette wrote:
> Thanks for the tips Mark. The funny thing about this specific problem
> is that it occurred with a fresh install from the PostGIS website. I
> was only able to 'discover' _STAsKML() but grepping through
> lwpostgis.sql
> Ideas?
> Dylan
Aha. A quick look at lwpostgis.sql.in shows that ST_AsKML() requires
PROJ.4 in order to run. So it sounds as if configure didn't find it for
some reason, either because it wasn't installed or your --with-proj
argument was wrong.
I think the minor bug here though is that _ST_AsKML() isn't included as
part of the #ifdef section which is why only this function is visible.
I'll go and fix this in 1.3 branch (trunk requires PROJ.4) - I wonder if
it's worth a note in the 1.3 documentation that ST_AsKML() requires
PROJ.4 support - Regina?
HTH,
Mark.
¡Felices Fiestas! Enviale una tarjeta electronica gratis a tu familia y amigos y deseales felices fiestas. http://yahoomorado.com/tarjetas/
