[postgis-users] Old (non-ST_) names don't use indexes?
Reid Priedhorsky
reid at umn.edu
Fri Dec 26 12:03:51 PST 2008
All,
Here are the query plans for two queries, identical except for the name
of the intersection function:
First, with Intersects():
> explain
> select Buffer(nodepoint, :wh_radius, 4) as wh_geometry
> from byway_extension be, byway_current b
> where
> be.byway_id != b.id
> and Intersects(be.extension, b.geometry);
> QUERY PLAN
> Nested Loop (cost=684.78..97841763.45 rows=1262371587 width=32)
> Join Filter: ((be.byway_id <> bs.id) AND intersects(be.extension, bs.geometry))
> -> Seq Scan on byway_segment bs (cost=0.00..6578.20 rows=151607 width=100)
> Filter: ((NOT deleted) AND (valid_before_rid = 2000000000))
> -> Materialize (cost=684.78..934.58 rows=24980 width=68)
> -> Seq Scan on byway_extension be (cost=0.00..659.80 rows=24980 width=68)
Second, with ST_Intersects():
> explain
> where
> be.byway_id != b.id
> and ST_Intersects(be.extension, b.geometry);
> QUERY PLAN
> Nested Loop (cost=0.00..31033.43 rows=6312 width=32)
> Join Filter: ((be.byway_id <> bs.id) AND _st_intersects(be.extension, bs.geometry))
> -> Index Scan using byway_segment_gist on byway_segment bs (cost=0.00..1.20 rows=1 width=100)
> Index Cond: (be.extension && bs.geometry)
> Filter: ((NOT bs.deleted) AND (bs.valid_before_rid = 2000000000) AND (be.extension && bs.geometry))
Note the wildly different plans; the first uses no indexes. I was under
the impression that while the old names were deprecated, the
functionality was identical to the new names. No?
Thanks,
Reid
