[postgis-users] Old (non-ST_) names don't use indexes?
Paragon Corporation
lr at pcorp.us
Fri Dec 26 12:15:40 PST 2008
Note the wildly different plans; the first uses no indexes. I was under the
impression that while the old names were deprecated, the functionality was
identical to the new names. No?
No. As your plan concludes -- old ones don't have built in indexes and new
ones do usually where possible.
The old ones are more comparable to the _ST_Intersects etc.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Reid
Priedhorsky
Sent: Friday, December 26, 2008 3:04 PM
To: PostGIS Users Discussion
Subject: [postgis-users] Old (non-ST_) names don't use indexes?
All,
Here are the query plans for two queries, identical except for the name of
the intersection function:
First, with Intersects():
> explain
> select Buffer(nodepoint, :wh_radius, 4) as wh_geometry
> from byway_extension be, byway_current b
> where
> be.byway_id != b.id
> and Intersects(be.extension, b.geometry);
> QUERY PLAN
> --------------- Nested Loop (cost=684.78..97841763.45
> rows=1262371587 width=32)
> Join Filter: ((be.byway_id <> bs.id) AND intersects(be.extension,
bs.geometry))
> -> Seq Scan on byway_segment bs (cost=0.00..6578.20 rows=151607
width=100)
> Filter: ((NOT deleted) AND (valid_before_rid = 2000000000))
> -> Materialize (cost=684.78..934.58 rows=24980 width=68)
> -> Seq Scan on byway_extension be (cost=0.00..659.80
Second, with ST_Intersects():
> explain
> where
> be.byway_id != b.id
> and ST_Intersects(be.extension, b.geometry);
> QUERY PLAN
> Nested Loop (cost=0.00..31033.43 rows=6312 width=32)
> Join Filter: ((be.byway_id <> bs.id) AND _st_intersects(be.extension,
bs.geometry))
> -> Seq Scan on byway_extension be (cost=0.00..659.80 rows=24980
width=68)
> -> Index Scan using byway_segment_gist on byway_segment bs
(cost=0.00..1.20 rows=1 width=100)
> Index Cond: (be.extension && bs.geometry)
> Filter: ((NOT bs.deleted) AND (bs.valid_before_rid =
> 2000000000) AND (be.extension && bs.geometry))
Thanks,
Reid
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
