[postgis-users] Pgrouting directions
Stephen Woodbridge woodbri at swoodbridge.com
Mon Dec 29 17:17:13 PST 2008
bdair2002 wrote:
> Hello,
> I am developing an application using Pgrouting with Postgis data, everything
> is fine, but now I am looking  to do something like Google directions guide,
> where it tells you turn left or right, I am wondering if this feature is a
> built-in feature in Pgrouting or Postgis.
> Regards
No this is not a feature that is part of either.
I have implemented a directions explicator, but it is somewhat specific
to the data that you have, as you need to know what column(s) contain
the road names, if you have signage information then you need to know
how to link to that. If you want to be able to explicate in multiple
languages, then you probably need to consider supporting multiple
languages each in a separate table the you can select from when you
generate the languages.
The algorithm is pretty straight forward as the you currently get a list
of segments that make up the route. Then you need to:
analyze each segment and
1) check to see if you want to join it with the previous segment because
the road name matches
2) check the angle that it makes with the last segment to determine
right, left, straightness of turn
3) compute the compass heading for the segment
4) determine if you have signage
5) based on these, determine if you are read to explicate and which
predefined instruction you need to explicate an instruction
6) loop through all segments
For a demo of this you can try:
http://imaptools.com/leaddog/routing/dd.html
Zoom into a city in one of the yellow areas, set a start and end point
and click [calculate route] button. The driving directions should show
below the button if it was successful, be patience the routing is
running on a 333MHz box.
-Steve
