[postgis-users] Re: How to populate a column with results of isvalid
Intengu Technologies
sindile.bidla at gmail.com
Wed Dec 31 09:17:19 PST 2008
Thanks Regina your solution was spot on.
On 12/31/08, Obe, Regina <robe.dnd at cityofboston.gov> wrote:
> You wouldn't use that for tagging. That is used if you want to prevent
> people from adding invalid geometries into your table. If you have
> already got invalid geometries it will just fail since you have already
> violated the rule you are trying to establish.
> To add a field
> ALTER TABLE mytable ADD COLUMN the_geom_is_valid boolean ;
> UPDATE mytable SET the_geom_is_valid = ST_IsValid(the_geom); //will
> update existing
> Unfortunately you can't put in a default value that references another
> column which I think you may be looking for if you want to continually
> add new data and have that field automatically fill. For that you'll
> need a (preferably BEFORE TRIGGER).
> Hope that helps,
> Regina
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Sent: Wednesday, December 31, 2008 10:25 AM
> To: PostGIS Users Discussion
> Subject: [postgis-users] How to populate a column with results of
> isvalid
> I have loaded a polygon shapefile into postgis and would like to tag
> each row with the results of st_isvalid in a new field. I found this
> query in the postgis manual "ALTER TABLE mytable ADD CONSTRAINT
> geometry_valid_check CHECK (isvalid((the_geom));" when I run the query
> it picks an invalid geometry and stops
> Sent from my mobile device
> Sindile Bidla
> postgis-users mailing list
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
Sindile Bidla
