[postgis-users] Thematic mapping with PostGIS
Johannes Sommer
johann.online at gmx.de
Sun Feb 10 00:38:16 PST 2008
Hi Doug,
As Desktop-Client for PostGIS - besides QGIS and UDIG - you can try:
- OpenJUMP(http://www.openjump.org) with the SISDB-Plugin (for improved
PostGIS-connections), thematic mapping (without the natural breaks routine)
- Kosmo (http://saig.es/en/index.php) , thematic mapping (without the
- gvSIG (http://www.gvsig.gva.es), thematic mapping with support of
natural breaks (the support for postgis-geometry-types is constrained =>
editing postgis-tables can be annoying)
- Spatial Commander (http://www.gdv.com/down/scommander.php) NON-OSS,
!only in GERMAN!, thematic mapping with support of natural breaks
(editing with postgis-tables can also be difficult)
- Thuban (http://thuban.intevation.org), thematic mapping without
natural breaks, but other possibilities
regards,
Johannes
Dan Putler schrieb:
> Hi Jim,
> QGIS (which is what I assume you mean by "Quantum") allows you to create
> thematic maps using PostGIS layers. Go to the properties of a layer and
> muck with the legend type. Alternatively, you can load PostGIS layers
> into uDig (http://udig.refractions.net), and alter the style of a layer.
> Dan
> On Sat, 2008-02-09 at 19:08 -0500, Doug Foster wrote:
>> I am new to PostGIS, and want a good Windows desktop mapping tool to
>> view and thematically map boundary data from my PostGIS database. I
>> have Quantum, which is a nice viewer, but it doesn’t seem to do
>> thematic mapping. I am a heavy MapInfo and Maptitude user, but they
>> don’t read PostGIS spatial boundaries. I wish they would.
>> Is there a free/inexpensive tool to view and do some nice thematics?
>> I would also like to have the “natural break” routine, which I use by
>> default since it’s the beast way to break up the categories.
>> I have been doing all my database work in SQL Server and then linking
>> from MapInfo and linking with equivalent boundary files (census block
>> groups and zip codes for all USA). That’s for the birds when I’m
>> running routines in SQL Server and want to view the results
>> graphically on an interactive basis. It’s very clumsy. So
>> PostgeSQL/PostGIS is a much better solution but I haven’t found a good
>> way to view the results spatially.
>> Thanks…..
>> Doug
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
