[postgis-users] Re: [postgis-devel] Proposal for supporting Extrude, Tesselate, and Altitudemode options in PostGIS KML generator
Paul Ramsey
pramsey at cleverelephant.ca
Mon Feb 18 15:35:21 PST 2008
How about ARRAY['extrude','1','tesselate','0','altitudeMode','clampToGround'] ?
Less parsing required, and still extendable.
P
On 2/18/08, Martin Davis <mbdavis at refractions.net> wrote:
> Ugh. Requiring complicated combinations of bit fields strikes me as
> being pretty error prone.
> What about providing a string parameter which can supply the various
> options in a human-readable format?
> E.g. "extrude=1 tesselate=0 altitudeMode=clampToGround"
> Easy to read, easy to parse, easy to extend...
> Paul Ramsey wrote:
> > I hope others are testing this out...
> > I have some aesthetic concerns with how you are passing arguments, I
> > wonder if there is a more elegant way do to it. I feel like requiring
> > a precision argument in order to do the other options would be
> > preferable to the "size of precision" hack to distinguish between
> > options and precision. Others may disagree.
> > P.
> > On 14-Feb-08, at 11:01 AM, Eduin Carrillo wrote:
> >> Add the possibility to customize KML code produced by PostGIS with
> >> altitude mode (altitudeMode), allow lines and paths to follow the
> >> terrain (tessellate), and how to connect primitive to the ground
> >> (extrude).
> >> http://code.google.com/p/postexperiments/wiki/Extrude_Tesselate_and_Altitudemode_Support
> >> http://code.google.com/p/postexperiments/issues/detail?id=1
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Martin Davis
> Senior Technical Architect
> Refractions Research, Inc.
> (250) 383-3022
