[postgis-users] The lazy donut maker
Kevin Neufeld
kneufeld at refractions.net
Mon Jan 28 08:40:55 PST 2008
Yes. ST_Collect your Linestrings together and pass them to
ST_BuildArea(). The return type can be a Polygon, MultiPolygon, or NULL
(if input linework does not form polygons). You may want to use
ST_Dump() to convert a MultiPolygon result into a set of Polygons.
-- Kevin
Gustavo Ces wrote:
> Hi,
> maybe this is a recurrent question but, is it possible to create
> polygons with holes in postgis directly? What i want to know is, given
> two concentric circles, with different radius, can postgis make
> directly (with no other data, as "the inner circle is a hole or is
> another polygon") two polygons ( the donut and the hole)?
> I´ve got a group of closed lines, some of them inside the others (
> polygons inside polygons). I want postgis to create the areas with
> autodetection of holes, etc...
> Any help?
> Thanks in advance,
> Gus
> postgis-users mailing list
