[postgis-users] RE: newbie question
Thomas Crosslin
tcrosslin at integral-corp.com
Thu Jan 31 13:17:04 PST 2008
Thanks to Paul and Stephen, both of your suggestions worked great.
I have a follow up question that Paul may be interested in.
When working on the below, I loaded three polygon shapefiles to my DB.
I used shp2pgsql to load my shapefiles to a sql file and then loaded and
ran the sql through PGAdminIII
I also have a raster grid that I need to query at the same time - but
since rasters aren't supported, I thought that I could convert the
raster grid to a point grid. This is an elevation grid, so each point
has only an elevation attribute.
When I run shp2pgsql on the resulting point shapefile, it creates a sql
file with no problems.
However, when I run the sql file in PGAdminIII, PGAdminIII terminates
without any errors or warnings - just shuts down.
I've tried this several times, trying to make sure that I wasn't making
a mistake - but can't find any.
Is there a file size limit either in PGAdminIII or in PostGIS/PostgreSQL
that might be causing this issue?
Any ideas of why the sql file would cause PGAdminIII to terminate and is
there an alternate means of loading this data?
-Thomas
Message: 6
Date: Fri, 25 Jan 2008 22:06:32 -0800
Subject: Re: [postgis-users] newbie question
To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Message-ID: <7C2F8D01-D121-419E-BE95-36BCFFE6569B at refractions.net>
Content-Type: text/plain; charset=WINDOWS-1252; delsp=yes;
format=flowed
Or the more succinct and modern
SELECT the_geom, zone
FROM r_zones
WHERE
ST_Contains(the_geom,GeomFromText('POINT(7644373.465626
687692.342075)', 2838));
On 25-Jan-08, at 8:14 PM, Stephen Woodbridge wrote:
> Try:
> FROM r_zones
> WHERE
> setsrid(makepoint(7644373.465626, 687692.342075), 2838) && the_geom
> and within(setsrid(makepoint(7644373.465626, 687692.342075), 2838),
> the_geom);
> Now this assumes that the_geom of r_zones is also in srid 2838. If not
> you will need to project the point into whatever srid that r_zones is
> in.
> HTH,
> -Stephen Woodbridge
> http://imaptools.com/
> Thomas Crosslin wrote:
>> I'm a new PostGIS/PostgreSQL user.
>> I've successfully set up my database and uploaded a few shapefiles to
>> play with.
>> I want to do some spatial queries and I'm having some difficulty.
>> I'd like to extract the polygon that a point intersects - actually I
>> really want to be able to intersect several layers at once with a
>> given point and return the values from a particular field from each
>> layer. But I decided to start with one layer. So the table is
>> called "r_zones" (it is an imported shapefile) and the field I want
>> information returned from is called "zone". So what I want is to
>> know what "zone" the point falls within. I'm using PgAdmin (v1.6.2)
>> to query my database, Windows, Postgres8.2, PostGIS 1.3.1.
>> So I've tried a basic query like this:
>> FROM r_zones
>> WHERE GeomFromText('POINT(7644373.465626 687692.342075)', 2838) I
>> know the WHERE statement is incorrect, I've tried several variants
>> looking at the docs (like using a distance based query and others)
>> but cannot make a successful query. Where am I going wrong?
>> Any help appreciated.
>> -Thomas
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080131/fdd8f39d/attachment.html>
