[postgis-users] RE: newbie question
Paul Ramsey
pramsey at refractions.net
Thu Jan 31 13:46:25 PST 2008
Yes, you are asking too much of PgAdminIII. It loads the whole SQL
file into memory, then executes it, so a huge file will kill it.
Use the psql commandline utility instead, to directly pipe the file
from disk to database.
psql -f myfile.sql -U myusername -d mydatabase
On 31-Jan-08, at 1:17 PM, Thomas Crosslin wrote:
> Thanks to Paul and Stephen, both of your suggestions worked great.
> I have a follow up question that Paul may be interested in.
> When working on the below, I loaded three polygon shapefiles to my DB.
> I used shp2pgsql to load my shapefiles to a sql file and then
> loaded and ran the sql through PGAdminIII
> I also have a raster grid that I need to query at the same time –
> but since rasters aren’t supported, I thought that I could convert
> the raster grid to a point grid. This is an elevation grid, so
> each point has only an elevation attribute.
> When I run shp2pgsql on the resulting point shapefile, it creates a
> sql file with no problems.
> However, when I run the sql file in PGAdminIII, PGAdminIII
> terminates without any errors or warnings – just shuts down.
> I’ve tried this several times, trying to make sure that I wasn’t
> making a mistake – but can’t find any.
> Is there a file size limit either in PGAdminIII or in PostGIS/
> PostgreSQL that might be causing this issue?
> Any ideas of why the sql file would cause PGAdminIII to terminate
> and is there an alternate means of loading this data?
> -Thomas
> Message: 6
> Date: Fri, 25 Jan 2008 22:06:32 -0800
> From: Paul Ramsey <pramsey at refractions.net>
> Subject: Re: [postgis-users] newbie question
> To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
> Message-ID: <7C2F8D01-D121-419E-BE95-36BCFFE6569B at refractions.net>
> Content-Type: text/plain; charset=WINDOWS-1252; delsp=yes;
> format=flowed
> Or the more succinct and modern
> SELECT the_geom, zone
> FROM r_zones
> WHERE
> ST_Contains(the_geom,GeomFromText('POINT(7644373.465626
> 687692.342075)', 2838));
> On 25-Jan-08, at 8:14 PM, Stephen Woodbridge wrote:
> > Try:
> > FROM r_zones
> > WHERE
> > setsrid(makepoint(7644373.465626, 687692.342075), 2838) &&
> the_geom
> > and within(setsrid(makepoint(7644373.465626, 687692.342075),
> 2838),
> > the_geom);
> > Now this assumes that the_geom of r_zones is also in srid 2838.
> If not
> > you will need to project the point into whatever srid that
> r_zones is
> > in.
> > HTH,
> > -Stephen Woodbridge
> > http://imaptools.com/
> >> I’m a new PostGIS/PostgreSQL user.
> >> I’ve successfully set up my database and uploaded a few
> shapefiles to
> >> play with.
> >> I want to do some spatial queries and I’m having some difficulty.
> >> I’d like to extract the polygon that a point intersects –
> actually I
> >> really want to be able to intersect several layers at once with a
> >> given point and return the values from a particular field from each
> >> layer. But I decided to start with one layer. So the table is
> >> called “r_zones” (it is an imported shapefile) and the field I want
> >> information returned from is called “zone”. So what I want is to
> >> know what “zone” the point falls within. I’m using PgAdmin
> (v1.6.2)
> >> to query my database, Windows, Postgres8.2, PostGIS 1.3.1.
> >> So I’ve tried a basic query like this:
> >> FROM r_zones
> >> WHERE GeomFromText('POINT(7644373.465626 687692.342075)', 2838) I
> >> know the WHERE statement is incorrect, I’ve tried several variants
> >> looking at the docs (like using a distance based query and others)
> >> but cannot make a successful query. Where am I going wrong?
> >> Any help appreciated.
> >> -Thomas
> postgis-users mailing list
