[postgis-users] facing problems while loading lwpostgis.sql in PostGIS
ahmadbasha.shaik at wipro.com
Thu Jan 31 21:38:43 PST 2008
Hi
I am facing problems while loading lwpostgis.sql in PostGIS. Below is a
detailed explanation.
psql -d test -f /usr/share/lwpostgis.sql
ERROR: could not access file "$libdir/liblwgeom.so.1.2": No such file
or directory
ERROR: current transaction is aborted, commands ignored until end of
transaction block
Hence , I tried creating a simple test.sql which has the create replace
functions for histogram. I have detailed the environmnent that we are
using, the statement of lwpostgis.sql we executed and the error
encountered
Environment:
Operationg System : Red Hat Linux 3.4.5-2
Database : PostgreSQL 8.2.6
Extensions : geos-3.0.0, proj-4.6.0, postgis-1.2.1
test.sql (three sql commands that I have taken from lwpostgis.sql to
check)
BEGIN;
CREATE OR REPLACE FUNCTION histogram2d_in(cstring)
RETURNS histogram2d
AS '$libdir/liblwgeom.so.1.2', 'lwhistogram2d_in'
LANGUAGE 'C' IMMUTABLE STRICT; -- WITH (isstrict);
CREATE OR REPLACE FUNCTION histogram2d_out(histogram2d)
RETURNS cstring
AS '$libdir/liblwgeom.so.1.2', 'lwhistogram2d_out'
CREATE TYPE histogram2d (
alignment = double,
internallength = variable,
input = histogram2d_in,
output = histogram2d_out,
storage = main
COMMIT;
ERROR Encountered
BEGIN
psql:test.sql:6: NOTICE: type "histogram2d" is not yet defined
DETAIL: Creating a shell type definition.
psql:test.sql:6: ERROR: could not access file
"$libdir/liblwgeom.so.1.2": No such file or directory
psql:test.sql:11: ERROR: current transaction is aborted, commands
ignored until end of transaction block
psql:test.sql:19: ERROR: current transaction is aborted, commands
ROLLBACK
Varions Options we tried:
a) /usr/local/lib is present in /etc/ld.so.conf
b) ldconfig was executed
c) Changed the permissions $libdir i.e. /usr/lib/pgsql to 777
d) Hardcoded the path /usr/lib/pgsql in this test.sql
e) We also tried hardcoding the path /usr/lib/pgsql instead of $libdir
in lwpostgis.sql when we tried loading functions and types in
lwpostgis.sql
f) When I hardcode the path /usr/lib/pgsql - it gives the following
error - could not load library "/usr/lib/pgsql/liblwgeom.so.1.2":
/usr/lib/pgsql/liblwgeom.so.1.2: undefined symbol: nth
Can somebody please guide us or give directions what can be done.
Please do not print this email unless it is absolutely necessary. Spread environmental awareness.
The information contained in this electronic message and any attachments to this message are intended for the exclusive use of the addressee(s) and may contain proprietary, confidential or privileged information. If you are not the intended recipient, you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately and destroy all copies of this message and any attachments.
WARNING: Computer viruses can be transmitted via email. The recipient should check this email and any attachments for the presence of viruses. The company accepts no liability for any damage caused by any virus transmitted by this email.
www.wipro.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080201/cb924aa7/attachment.html>
