[postgis-users] Cron / shp2psql
Dan Blomberg services at gpsfiledepot.com
Sun Jun 1 15:20:26 PDT 2008
On this note, I thought I had fixed my problem but it doesn't work
either.  I can even run it as a bat but I can't call the bat in visual
basic or just run the command that is in the bat file.
chris brisendine wrote:
> I have cron running a shell script "
> shp2pgsql -d -s 4326 /home/storm/ww/TOR.shp torpoly wxsvr>torpoly.sql
> sleep 7
> shp2pgsql -d -s 4326 /home/storm/ww/SVR.shp svrpoly wxsvr| psql -d  wxsvr
> echo `date`>updated.txt
> When i run this from the command line it works flawless but when cron
> runs it it dosent update my nwswarnings! Any idea's?
> I know the new warnings are being downloaded and the the script is
> running cause it writes to the updated.txt file when it runs.
> I have tryed it two different ways but no luck...
