[postgis-users] Intersection - No GID
Burgholzer,Robert
rwburgholzer at deq.virginia.gov
Tue Jun 3 12:06:33 PDT 2008
Marcus,
1) You could create your table prior to populating it, and include a column that is type "SERIAL", this will create an autogenerated integer identifier that you could name "gid" if you so desired.
2) select area2d(Intersection(f.the_geom, c.the_geom)) ...
NOTE: You will have to convert this area2d result from the units of your map projection into acres
3) ST_intersection and intersection are the same, the new (ST_*) naming convention was recently added, for reasons that I do not know but assume that they were good ones.
HTH,
Robert
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net on behalf of Marcus C. England
Sent: Tue 6/3/2008 2:57 PM
To: PostGIS Users Discussion
Cc:
Subject: [postgis-users] Intersection - No GID
Hi all,
I figured out how to use Intersection and get a resulting table with
apparently correct results using the example from the PostGIS website:
CREATE TABLE new_fields AS
SELECT
Intersection(f.the_geom, c.the_geom) AS the_geom,
f.attr1,
f.attr2,
c.clu_name
FROM
fields f,
clu c
WHERE
f.the_geom && c.the_geom
AND
Intersects(f.the_geom, c.the_geom)
However, this example does not create a gid column and I therefore can
not view the results in a GIS program. Is there a way to create a gid
column after-the-fact?
Optional questions for those feeling super-helpful:
(1) How should the above SQL be rewritten to include gid in the
resulting table?
(2) I know that eliminating the first line will simply give me a table
spit onto the SQL results in pgAdmin. How do I alter the SQL above to
give me the acreages rather then a list of the geometries? I can get the
acreages from the table resulting from the above, but I can't figure out
how to skip the step of creating a table.
(3) What is the syntax using ST_Intersection rather than Intersection?
thanks,
Marcus
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080603/57b18b4d/attachment.html>
