[postgis-users] Semantics of difference() function
Martin Davis mbdavis at refractions.net
Wed Jun 4 08:49:11 PDT 2008
Regina,
comments inline below
Obe, Regina wrote:
> On a slightly related note, I'm still confused about how differences in
> PostGIS work though particularly at the boundary level.
> E.g. why when you take a polygon difference out another polygon  - that
> your new difference intersects with both original polygons.
There's a couple of reasons this will happen.  One is roundoff error -
if the difference poly contains new vertices which are the result of
intersections of line segments, then it's very likely that the new
vertex will intersect one or other parent polygon.
The other reason is that the boundaries of the difference and input
polys will definitely intersect, since they both contain some of the
same linework.
The condition which difference actually should theoretically satisfy is
that the Interior of the difference poly will not intersect the Interior
of the poly it was subtracted from.  If you use inputs where
intersections can be computed exactly (e.g. rectangles) you should find
this holds.
> Well rather frankly I don't see how you would make it so it wouldn't,
> but seems to violate point set definition of difference to me (if you
> remove an intersecting part how can the new geometry intersect with the
> originals?). Seems like it should just touch but not intersect.
Note - touches() implies intersects().  As I mentioned above, you need
to be thinking in terms of testing Interior Intersection.  There are no
named predicates which do this - you have to work with the DE-9IM
pattern directly.  (I have added an interiorsIntersect predicate to JTS
to do just this, since it's useful in some situations.
> More disturbing is why when I cut a polygon with a line I get (shall we
> say bizarre results).  A slightly larger polygon.
This is a weird one. Can you post the actual geometries?  In JTS when I
try differencing a line from a circular point buffer, I get a single
polygon (with extra vertices where the line cut it).  This is the
expected behaviour.  I don't know why PostGIS/GEOS is doing something
different.
To answer a question you posed on your blog, the reason that when you
subtract a line from a polygon you get basically the same polygon,
rather than say the polygon split into two halves, is that if the latter
was provided as a MultiPolygon it would be invalid, because the halves
would share line segments down the middle.  Also, if the line did not
fully overlap the polygon there's no choice - you have to return the
original poly.  The behaviour is thus consistent between the two cases.
Unfortunately the SFS (and no other standard I'm aware of) doesn't
define the precise semantics of the overlay operations.  So I made 'em
up!  Hopefully they are consistent and reasonable.  There's no doubt
alternative definitions which might be useful in some cases - but you
have to choose one definition for any given function.  (For the
situation above, many people would like a "cut polygon by line"
operation - hopefully that will get provided as a new function sometime
soon).
HTH - Martin
> Thanks,
> Regina
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Martin Davis
> Sent: Tuesday, June 03, 2008 12:08 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] How to tell if 2 geometries are spatially
> equal
> Andy,
> Can you send me the PDF that you found?  That link appears to be dead.
> I realize that the SFS doesn't actually define equal.  I was the
> designer of JTS and GEOS, so the definition is due to me.  I followed
> what I thought was a logical extension of the other definitions, and
> something that was expressible in terms of the DE-9IM.  I also provided
> "equalsExact", which corresponds to the other proposed definition that
> you give.
> I will note that in fact according to the SFS, in the geometry
> LINESTRING(0 0, 5 5, 10 10)' the point (5,5) is *not* a boundary point.
> In fact, even in the geometry MULTILINESTRING((0 0, 5 5), (5 5, 10 10))
> the point (5 5) is not on the boundary, due to the (slightly bizarre)
> 'mod-2' rule used by the SFS.
> There's plenty of references that support the definition I chose (in
> fact, I suspect I chose it based on other references I scanned at the
> time):
> * The IBM Spatial Datablade manual says: Using the *ST_Equals()*
> function is functionally equivalent to using
> *ST_IsEmpty*(*ST_SymDifference*(/a/,/b/))
> (http://publib.boulder.ibm.com/infocenter/idshelp/v10/index.jsp?topic=/c
> om.ibm.spatial.doc/spat122.htm)
> ESRI gives the DE-9IM pattern of T*F**FFF* for ST_Equals, which is what
> JTS uses
> http://webhelp.esri.com/arcgisdesktop/9.2/index.cfm?TopicName=Spatial_re
> lationships
> Egenhofer has a paper on "Point-Set Topological Spatial Relations"
> (http://www.spatial.maine.edu/~max/pointset.pdf)
> There's also all the references given in the SFS paper.
> In the end it all comes down to naming.  There are various kinds of
> equality, which are useful for different things.  Different systems name
> them differently, which is ok as long as the semantics are documented.
> Of course, it's nice to have some standard names - and it looks to me
> like ST_equals is pretty well defined.
> Andy Anderson wrote:
>> On Jun 2, 2008, at 4:29 PM, Martin Davis wrote:
>>> I use "topologically equal" because the OGC SFS specification uses
>>> the term "topology" extensively in their discussion of the meaning of
>>> the DE-9IM model, on which the semantics of ST_equals is based.
>> No doubt they do, because the spatial relationships that can be
>> determined by the DE-9IM are, generally speaking, topological in
> nature:
>>     Disjoint, Touches, Crosses, Within and Overlaps
>> These are the ones defined here:
>>     http://portal.opengeospatial.org/files/?artifact_id=829
>> Oddly, in this document they also mention "Equals" but they never
>> explicitly define it (though they claim to later in the document).
>> However, I did find a very complete description of DE-9IM here:
>>     http://mlblog.osdir.com/gis.postgis/2004-02/pdfHaVE9FZPMj.pdf
>> and they say that for "equals", the "Geometries must be identical:
>> - Same dimension
>> - Same geometry type
>> - Same number of vertices
>> - All x,y coordinates must be identical"
>> So this definition would seem to agree with me that LINESTRING(0 0, 10
>> 10) and LINESTRING(0 0, 5 5, 10 10) are not topologically equal. The
>> best way to think of this is that the second is a *polyline*, and the
>> vertex (5, 5) is a boundary between two lines, and that changes the
>> DE-9IM.
>> As you point out, however, ST_equals('LINESTRING(0 0, 10
>> 10)','LINESTRING(0 0, 5 5, 10 10)') returns true; perhaps this was by
>> design to distinguish it from 'LINESTRING(0 0, 10 10)'::geometry ~=
>> 'LINESTRING(0 0, 5 5, 10 10)'::geometry .
>> If you can point to further discussion on this issue, I would be
>> interested.
>>> I don't like the term "spatially-equal", because I think "spatially"
>>> is too vague and overloaded.  How about "point-set equal"?  The idea
>>> is that  A = B iff every point of A is in B and every point of B is
>>> in A.
>> Personally, I don't have a problem with "spatially equal", it says to
>> me "they fill space in the same way", which in fact they do because a
>> point has no extent.
>> -- Andy
>>>> I wouldn't call this example "topologically" equal; one has two
>>>> vertices and the other has three, and that's the only characteristic
>>>> that's relevant in topology (not even their positions :-)
>>>> "Coincident" is probably a better term, though "spatially equal" is
>>>> probably just as good, and contrasts well with the term
>>>> "geometrically equal" that the manual uses to describe the ~=
> operator.
>>>> -- Andy
>>>> On May 30, 2008, at 7:54 PM, Martin Davis wrote:
>>>>> Will ST_equals do what you want?  It reports whether two geometries
>>>>> are topologically equal.
>>>>> (So for example, ST_equals('LINESTRING(0 0, 10 10)','LINESTRING(0
>>>>> 0, 5 5, 10 10)') is true)
>>>>> Obe, Regina wrote:
>>>>>> I recall this having come up before.  I always thought that ~=
> would
>>>>>> tell me if 2 geometries are spatially equal but it doesn't seem
> to.
>>>>>> The only way I can figure to determine spatial equality is if
>>>>>> ST_Within(A,B)  And  ST_Within(B,A)  (or ST_Difference(A,B) AND
>>>>>> ST_Difference(B,A) both return an empty geometry collection)
>>>>>> --So case in point
>>>>>> SELECT geom1 ~= geom2 as what, ST_Within(geom1, geom2) AND
>>>>>> ST_Within(geom2, geom1) As spatial_equal,
>>>>>>    ST_AsText(ST_Difference(geom1, geom2)) as diffgeom12,
>>>>>> ST_AsText(ST_Difference(geom2, geom1)) as diffgeom21 FROM (SELECT
>>>>>> 'LINESTRING(1 1, 1 2, 1 3)'::geometry As geom1,     'LINESTRING(1
>>>>>> 1, 1 3)'::geometry As geom2) As foo
>>>>>> Results:
>>>>>> what | spatial_equal |        diffgeom12        |
> diffgeom21
>>>>>> f    | t             | GEOMETRYCOLLECTION EMPTY |
> GEOMETRYCOLLECTION
>>>>>> EMPTY
>>>>>> Is there a function / operator that does that (also what does
> geom1 =
>>>>>> geom2 compare - is it just bounding boxes or is that the spatially
>>>>>> equal
>>>>>> operator I am looking for?)
>>>>>> Thanks,
>>>>>> Regina
>>>>>> The substance of this message, including any attachments, may be
>>>>>> confidential, legally privileged and/or exempt from disclosure
>>>>>> pursuant to Massachusetts law. It is intended
>>>>>> solely for the addressee. If you received this in error, please
>>>>>> contact the sender and delete the material from any computer.
>>>>>> _______________________________________________
>>>>>> postgis-users mailing list
>>>>>> postgis-users at postgis.refractions.net
>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>>> Martin Davis
>>>>> Senior Technical Architect
>>>>> Refractions Research, Inc.
>>>>> (250) 383-3022
>>> Martin Davis
>>> (250) 383-3022
Martin Davis
(250) 383-3022
