[postgis-users] create tables smarter
Chris Hermansen chris.hermansen at timberline.ca
Wed Jun 4 16:19:11 PDT 2008
Kevin, I'm always game to try something that's potentially worthwhile :-)
    clh=# create table tracks (tablename name);
    CREATE TABLE
    clh=# create rule table_rule as on insert to pg_class do also
    insert into tracks values (new.relname);
    CREATE RULE
    clh=# create table foo (a int, b text);
    CREATE TABLE
    clh=# create table bar (c float, d date);
    CREATE TABLE
    clh=# select * from tracks;
     tablename
    (0 rows)
    clh=# select * from pg_class where relname = 'foo';
     relname | relnamespace | reltype | relowner | relam | relfilenode |
    reltablespace | relpages | reltuples | reltoastrelid | reltoastidxid
    | relhasindex | relisshared | relkind | relnatts | relchecks |
    reltriggers | relukeys | relfkeys | relrefs | relhasoids |
    relhaspkey | relhasrules | relhassubclass | relfrozenxid | relacl |
    reloptions
     foo     |         2200 |   24623 |    16384 |     0 |       24621
    |             0 |        0 |         0 |         24624 |
    0 | f           | f           | r       |        2 |         0
    |           0 |        0 |        0 |       0 | f          |
    f          | f           | f              |          655 |        |
    (1 row)
    clh=#
Oh well.
Kevin Neufeld wrote:
> Chris Hermansen wrote:
>> OK, so far, so good.  Let's try the same thing with pg_tables:
>>     clh=# drop rule table_rule on data;
>>     DROP RULE
>>     clh=# drop table tracks;
>>     DROP TABLE
>>     clh=# drop table data;
>>     DROP TABLE
>>     CREATE TABLE
>>     clh=# create rule table_rule as on insert to pg_tables do also
>>     insert into tracks values (new.tablename);
>>     CREATE RULE
>>     clh=# create table fink (a int, b text);
>>     CREATE TABLE
>>     clh=# create table zink (c float, d date);
>>     CREATE TABLE
>>      tablename
>>     (0 rows)
>>     clh=#
>> Well, so much for that idea.  We can create rules on system tables, they
>> just don't work.
>> Bummer.
> Just thought I'd point out Chris that pg_tables is a view, not a
> system table.  For kicks, try your rule on pg_class.
> -- Kevin
> postgis-users mailing list
Regards,
Chris Hermansen         mailto:chris.hermansen at timberline.ca
tel+1.604.714.2878 · fax+1.604.733.0631 · mob+1.778.232.0644
Timberline Natural Resource Group · http://www.timberline.ca
401 · 958 West 8th Avenue  · Vancouver BC · Canada · V5Z 1E5
