[postgis-users] Semantics of difference() function
Andy Anderson
aanderson at amherst.edu
Mon Jun 9 14:58:10 PDT 2008
Sorry, I tend to think of "sides" in a linear sense rather than a
radial sense, so I was not interpreting your last comment properly.
In any case, you mean three operations -- difference, intersection,
and collect:
select st_astext(st_collect(
st_difference(GEOMFROMTEXT('LINESTRING(-1 1, 3 1)'),
GEOMFROMTEXT('POLYGON((0 0, 2 0, 2 2, 0 2, 0 0))')),
st_intersection(GEOMFROMTEXT('LINESTRING(-1 1, 3 1)'),
returns
'GEOMETRYCOLLECTION(MULTILINESTRING((-1 1,0 1),(2 1,3
1)),LINESTRING(0 1,2 1))'
"Total runtime: 1.270 ms"
But you really only need two, boundary and difference:
select st_astext(
ST_Boundary(GEOMFROMTEXT('POLYGON((0 0, 2 0, 2 2, 0 2, 0 0))'))))
returns
'MULTILINESTRING((-1 1,0 1),(0 1,2 1),(2 1,3 1))'
This doesn't significantly increase performance, though:
"Total runtime: 1.207 ms"
Round-off issues should be much less, I think.
My previous case with a solid Polygon split ("the sledgehammer" rather
than "the ring axe") has "Total runtime: 0.469 ms".
I'll be interested to see what you come up with!
-- Andy
On Jun 9, 2008, at 3:18 PM, Martin Davis wrote:
> Yes - but it doesn't provide the section LINESTRING(0 1, 2 1) inside
> the polygon. I envision this also being provided by split().
> (Otherwise you have to run two operations, difference and
> intersection - with the associated performance penalty, and also a
> risk that round-off will cause results to be computed which don't
> precisely match)
> Andy Anderson wrote:
>> Difference does seem to provide both sides of the subtractor:
>> select st_astext(st_difference(GEOMFROMTEXT('LINESTRING(-1 1, 3
>> 1)'),
>> returns
>> 'MULTILINESTRING((-1 1,0 1),(2 1,3 1))'
>> -- Andy
>> On Jun 9, 2008, at 2:44 PM, Martin Davis wrote:
>>> I see the difference (pun intended) between difference() and
>>> split() being that split returns the geometries on both sides of
>>> the splitting geometry, ordered so that the user can decide which
>>> one(s) he wants. This is more powerful than difference, which
>>> only returns a single geometry from one side of the split.
>>> And I agree - I don't think polygons should be reduced to their
>>> boundary first - the user can do this explicitly if they require it.
>>>> On Jun 5, 2008, at 11:43 AM, Martin Davis wrote:
>>>>> I think the operation also is meaningful for the case (line,
>>>>> polygon) => line (this is equivalent to a combination of
>>>>> line.difference(polygon) and line.intersection(polygon) )
>>>> Ah, yes, split(line, polygon) should definitely be allowed.
>>>> However, I was originally imagining that split(line, polygon), as
>>>> well as split(polygon1, polygon2), should be the same as
>>>> difference(*, polygon), which is geometrically consistent with
>>>> the simpler forms split(*, line) and split(line, point):
>>>> ----####---> becomes ---> --->
>>>> #### 1 2
>>>> But I see where it might be more useful for the polygon in the
>>>> second argument to be reduced to its boundary first:
>>>> #### +--+ ----####---> becomes
>>>> ----|--|---> becomes ---> ---> --->
>>>> #### +--+ 1 2 3
>>>> But the latter is easily produced with the boundary function if
>>>> someone is so inclined:
>>>> split(polygon1, polygon2) == split(polygon1, boundary(polygon2))
>>>> split(line, polygon) == split(line, boundary(polygon))
>>>> This is more involved, but less confusing to those like me who
>>>> learn from consistency. What do other people think?
>>>>> Having thought about this with an eye to implementation, I've
>>>>> take the definition a bit further:
>>>>> * The result of split(g1, g2) is a two-component
>>>>> GeometryCollection, GC(c1, c2).
>>>> If you define split(line, polygon) as the combination of
>>>> difference(line, polygon) and intersection(line, polygon), then
>>>> you could have three components, right? This would also happen
>>>> with split(line1, line2) and line2 is a linear ring that crosses
>>>> line1 twice.
>>>>> * The first component c1 is the portion of g1 which lies to
>>>>> inside, to the left of, or before, g2 (depending on whether g2
>>>>> is a polygon, line or point). The second component c2 is the
>>>>> portion of g1 which lies outside, to the right of, or after g2.
>>>>> * The types of c1 and c2 are the same as g1. c1 and c2 may be
>>>>> empty, in degenerate cases (e.g,. where one or more components
>>>>> of g1 are not intersected, or intersected only at their boundary).
>>>> It seems to me that "left" and "right" don't always work for
>>>> lines, as you could also have "below" or "above". Or are you
>>>> referencing the directionality of g2 here, as you traverse it?
>>>> But if it's a linear ring, the inner portion will be both to the
>>>> left and right. I wonder if it wouldn't make more sense to simply
>>>> use the directionality of g1 instead, describing its pieces as
>>>> "first", "second", etc., as I suggest in my drawings above?
>>>> As for polygons, there's no obvious spatial ordering for them,
>>>> unless you take their vertex order as significant. That seems
>>>> reasonable to me. For example,
>>>> split(POLYGON((0 0, 2 0, 2 2, 0 2, 0 0)), LINESTRING(1 -1, 1 3))
>>>> becomes GEOMETRYCOLLECTION(POLYGON((0 0, 1 0, 1 2, 0 2, 0 0)),
>>>> POLYGON((1 0, 2 0, 2 2, 1 2, 1 0)))
>>>> because the first polygon has the first vertex of the original
>>>> and the second polygon is built from later vertices. I'm not
>>>> certain if this could be consistently defined, though; it would
>>>> require comparisons of multiple vertices when one or more are
>>>> shared by the split polygons.
>>>>> * Any components of g2 which have a position which is not well-
>>>>> defined relative to g2 (e.g.which are not intersected, or which
>>>>> are intersected only partially), are returned as components of
>>>>> c1 (--- this rule is fairly arbitrary - a different strategy
>>>>> might make equal sense)
>>>> So c1 is itself a Geometry Collection? This seems unnecessarily
>>>> complicated; I would prefer a flat object.
>>>> -- Andy
>>>>>> On Jun 4, 2008, at 11:49 AM, Martin Davis wrote:
>>>>>>> To answer a question you posed on your blog, the reason that
>>>>>>> when you subtract a line from a polygon you get basically the
>>>>>>> same polygon, rather than say the polygon split into two
>>>>>>> halves, is that if the latter was provided as a MultiPolygon
>>>>>>> it would be invalid, because the halves would share line
>>>>>>> segments down the middle. Also, if the line did not fully
>>>>>>> overlap the polygon there's no choice - you have to return the
>>>>>>> original poly. The behaviour is thus consistent between the
>>>>>>> two cases.
>>>>>>> Unfortunately the SFS (and no other standard I'm aware of)
>>>>>>> doesn't define the precise semantics of the overlay
>>>>>>> operations. So I made 'em up! Hopefully they are consistent
>>>>>>> and reasonable. There's no doubt alternative definitions
>>>>>>> which might be useful in some cases - but you have to choose
>>>>>>> one definition for any given function. (For the situation
>>>>>>> above, many people would like a "cut polygon by line"
>>>>>>> operation - hopefully that will get provided as a new function
>>>>>>> sometime soon).
>>>>>> I've seen "split" as a term that is commonly used for such
>>>>>> operations, e.g.
>>>>>> geometry = ST_Split(geometry1, geometry2)
>>>>>> This should be defined for geometry1 of dimensionality D ≥ 1
>>>>>> and geometry2 of dimensionality D or D-1, i.e. (polygon,
>>>>>> polygon), (polygon, line), (line, line), and (line, point). The
>>>>>> result should be GeometryType(geometry) == 'GeometryCollection'
>>>>>> where for any n GeometryType(ST_GeometryN(geometry, n)) ==
>>>>>> GeometryType(geometry1).
>>>>>> -- Andy
>>>>>> _______________________________________________
>>>>>> postgis-users mailing list
>>>>>> postgis-users at postgis.refractions.net <mailto:postgis-users at postgis.refractions.net
>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>>> Martin Davis
>>>>> Senior Technical Architect
>>>>> Refractions Research, Inc.
>>>>> (250) 383-3022
>>> Martin Davis
>>> (250) 383-3022
> Martin Davis
> (250) 383-3022
