[postgis-users] Buffer select from one layer to another?
    Obe, Regina
    robe.dnd at cityofboston.gov
    Wed Jun 11 12:38:28 PDT 2008
ST_Buffer is the new MM naming convention.  For relation operators ST
adds the && index operator where as the ones without ST_
you have to do
A && B AND relation(A,B)
Vs.
just
ST_Relation(A,B)
In most cases like ST_Buffer and Buffer, Difference,  (things in general
that create geometries) they are identical.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Abram Gillespie
Sent: Wednesday, June 11, 2008 3:22 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Buffer select from one layer to another?
I think this bounced ... sorry if it's a dupe.
Indeed, that was noticeably faster.  Thanks!
This brings up a good point, albeit OT for this thread:
What's the difference between using st_* and other functions w/o the
st_ prefix.  For example, why is there both st_buffer() and buffer()?
-Abe
zigGIS Team
Obtuse Software, http://www.obtusesoft.com
On Wed, Jun 11, 2008 at 2:39 PM, Obe, Regina <robe.dnd at cityofboston.gov>
wrote:
> Abe,
> David's is close but doesn't use an index
> Try
> SELECT  h.* FROM  houses h, roads r
> where r.gid=1663 and  ST_DWithin(h.the_geom, r.the_geom, 500)
> (although the above really translates to < 500 instead of <= 500)
> Hope that helps,
> Regina
> ________________________________
> From: postgis-users-bounces at postgis.refractions.net on behalf of David
> William Bitner
> Sent: Wed 6/11/2008 2:08 PM
> Abe --
> For this type of query, running a buffer is actually not necessary.
> select h.* from houses h,roads r where r.name like '%MAIN%' and
> distance(h.the_geom,r.the_geom)<=500;
> David
> On Wed, Jun 11, 2008 at 12:54 PM, Abram Gillespie
> <abe.gillespie.lists at gmail.com> wrote:
>> Hi All,
>> I'm finally starting to do some real production work ... after years
>> of simply using PostGIS in example scenarios as I developed zigGIS.
>> Pretty funny, actually.  Anywho, could someone enlighten me on how to
>> buffer a road and return the surrounding buildings?  This is what I
>> have so far:
>> touches(h.the_geom, buffer(r.the_geom,500));
>> Now I realize the above is a bit complex since " like '%MAIN%' "
>> returns multiple road segments, but even working on a single road:
>> select h.* from houses h,roads r where r.gid=1663 and
>> doesn't seem to return anything.  I'm positive the buffer query
should
>> return some houses.
>> Thanks for any help!
>> -Abe
>> zigGIS Team
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> David William Bitner
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
pursuant to
> Massachusetts law. It is intended solely for the addressee. If you
received
> this in error, please contact the sender and delete the material from
any
> computer.
> Help make the earth a greener place. If at all possible resist
printing this
> email and join us in saving paper.
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
