[postgis-users] Postgis for geology work
Randy George
rkgeorge at cadmaps.com
Thu Jun 12 10:18:39 PDT 2008
Hi Gus,
These might also be useful: gdal_grid, gdal_contour
http://www.gdal.org/gdal_grid.html http://www.gdal.org/gdal_contour.html
> I´ve got to separate visualization and operations ( make something and
then visualize in browser or other software ).
What are you looking at to visualize 3D Models in browser?
Map viewing:
1. OpenLayers is 2D
2. SVG is 2D
Globe viewers:
3. GoogleEarth has nice 3D but is pretty much a read only globe
viewer with google terrain and has license issues for commercial users. The
models you are needing would be hard to overlay as kml polygons
4. Virtual Earth 3D similar to Google with same problems. Low
performance on heavy external datasets.
5. NASA World Wind - I think it has/is moving to a .NET base (does
this mean Windows only), source is available but geared to global terrain 3D
General 3D scene viewers:
6. WPF is 3D but is still limited to IE clients and XBAP/XAML (XBAP
works somewhat like Java Web Start)
It is somewhat promising for IE web viewing, and could be used for
rendering gridded subsurface models and volume models. (Windows Firefox
.Net3.5, Safari plugin future? Linux doubtful? Silverlight WPF 2D subset
only)
7. X3D what viewers do people recommend? How does X3D work as
browser plugin?
randy
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Obe,
Regina
Sent: Thursday, June 12, 2008 9:29 AM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] Postgis for geology work
Gus,
Have you checked out California Soil Resource Lab. Dylan has a lot of good
examples on there involving soil using Grass, R, and PostGIS and I think he
has some 3D examples although I guess they are mostly 2D. I'm not sure it
would have anything of interest to you. I think its worth a look if you
haven't already.
http://casoilresource.lawr.ucdavis.edu/drupal/tracker
Hope that helps,
Regina
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Gustavo
Ces
Sent: Thursday, June 12, 2008 11:09 AM
Subject: Re: [postgis-users] Postgis for geology work
Hi Chris,
to be honest, i´d prefer to code just what i need! :)
I was looking for software to do those tasks and only found comercial
software ( Rockware,Gemm, oasis montaj, target,...). What i need is a 3d
environment, gis and postgis interaction,with some geological functions or
with capacity to implement those in python... Grass 6 seems to be an
interesting option ! Do you know any geological application to subsurface
modelling with GRASS?
Thanks for answering!
Gus
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
