[postgis-users] Postgis for geology work
Luigi Castro Cardeles luigi.cardeles at gmail.com
Thu Jun 12 23:14:09 PDT 2008
hi,
you can see x3d for 3d visualization at www.open3dgis.org. It uses postgis
as backend for data, and web browsing for viewer.
[]'s
2008/6/12 Randy George <rkgeorge at cadmaps.com>:
> Hi Gus,
>        These might also be useful: gdal_grid, gdal_contour
> http://www.gdal.org/gdal_grid.html  http://www.gdal.org/gdal_contour.html
> > I´ve got to separate visualization and operations ( make something and
> then visualize in browser or other software ).
> What are you looking at to visualize 3D Models in browser?
> Map viewing:
>        1. OpenLayers is 2D
>        2. SVG is 2D
> Globe viewers:
>        3. GoogleEarth has nice 3D but is pretty much a read only globe
> viewer with google terrain and has license issues for commercial users. The
> models you are needing would be hard to overlay as kml polygons
>        4. Virtual Earth 3D similar to Google with same problems. Low
> performance on heavy external datasets.
>        5. NASA World Wind - I think it has/is moving to a .NET base (does
> this mean Windows only), source is available but geared to global terrain
> 3D
> General 3D scene viewers:
>        6. WPF is 3D but is still limited to IE clients and XBAP/XAML (XBAP
> works somewhat like Java Web Start)
>         It is somewhat promising for IE web viewing, and could be used for
> rendering gridded subsurface models and volume models. (Windows Firefox
> .Net3.5, Safari plugin future? Linux doubtful? Silverlight WPF 2D subset
> only)
>        7. X3D what viewers do people recommend? How does X3D work as
> browser plugin?
> randy
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Obe,
> Regina
> Sent: Thursday, June 12, 2008 9:29 AM
> To: PostGIS Users Discussion
> Subject: RE: [postgis-users] Postgis for geology work
> Gus,
> Have you checked out California Soil Resource Lab.  Dylan has a lot of good
> examples on there involving soil using Grass, R, and PostGIS and I think he
> has some 3D examples although I guess they are mostly 2D.  I'm not sure it
> would have anything of interest to you.  I think its worth a look if you
> haven't already.
> http://casoilresource.lawr.ucdavis.edu/drupal/tracker
> Hope that helps,
> Regina
> Gustavo
> Ces
> Sent: Thursday, June 12, 2008 11:09 AM
> Subject: Re: [postgis-users] Postgis for geology work
> Hi Chris,
>    to be honest, i´d  prefer to code just what i need! :)
> I was looking for software to do those tasks and only found comercial
> software ( Rockware,Gemm, oasis montaj, target,...). What i need is a 3d
> environment, gis and  postgis interaction,with some geological functions or
> with capacity to implement those in python... Grass 6 seems to be an
> interesting option ! Do you know any geological application to subsurface
> modelling with GRASS?
> Thanks for answering!
> Gus
> postgis-users mailing list
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080613/5114ead9/attachment.html>
