[postgis-users] Postgis installation - Trouble with 'make check'
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Fri Jun 20 02:24:26 PDT 2008
Paul Ramsey wrote:
> What GEOS are you using, Bill? Your PostGIS is mismatched to the GEOS.
> Or, at least, *something* is mismatched. Do you have old GEOS libs
> hanging around? Old postgis libs? Try really reaming out the system
> and ensure that the only things around are your new fresh builds.
> P
Yeah, I agree. If you are using 1.3.3 then you should find that
"topologypreservesimplify" should only be enabled if you are using a SVN
GEOS version (i.e. after 3.0.0). Maybe the output at the end of
configure will give you some clues as to which version you are picking up?
HTH,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
