[postgis-users] Bezier Support?
Paul Ramsey
pramsey at cleverelephant.ca
Sun Mar 9 22:00:24 PDT 2008
Nope, SQL/MM only specifies circular arcs. At this point, I'll be
happy just to get that support roughed in fully.
P
On 3/9/08, Jeshua Lacock <jeshua at 3dtopo.com> wrote:
> Greetings,
> I am wondering if bezier type paths are supported with PostGIS. The
> path is comprised of segments with an "anchor" point (X,Y) and a
> "in" (X,Y) and "out" (X,Y) point. The anchor point is where the
> segment is located and the in and out points of a segment define the
> tangent of the curve at point.
> I looked at the SQL-MM definitions, but I do not see a way to use them
> for a bezier type curve:
> CIRCULARSTRING(0 0, 1 1, 1 0)
> COMPOUNDCURVE(CIRCULARSTRING(0 0, 1 1, 1 0),(1 0, 0 1))
> CURVEPOLYGON(CIRCULARSTRING(0 0, 4 0, 4 4, 0 4, 0 0),(1 1, 3 3, 3 1, 1
> 1))
> MULTICURVE((0 0, 5 5),CIRCULARSTRING(4 0, 4 4, 8 4))
> Will I have to store the anchor points as a LINESTRING and created a
> relational table for the in and out points?
> And advice is greatly appreciated!
> Many Thanks,
> Jeshua Lacock
> Founder/Programmer
> 3DTOPO Incorporated
> <http://3DTOPO.com>
> Phone: 877.240.1364
> postgis-users mailing list
