[postgis-users] ST_AsKML changes in 1.3.3
Dylan Beaudette
dylan.beaudette at gmail.com
Wed Nov 19 07:54:36 PST 2008
On Wed, Nov 19, 2008 at 4:21 AM, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> Dylan Beaudette wrote:
>> OK. What is going on with AsKML in PostGIS 1.3.3 ? It looks like there
>> are two new mandatory arguments (version and precision), and the
>> function name is prefixed by an underscore.
>> This used to work:
>> ST_AsKML(geometry)
>> Now this is the only way to invoke the function:
>> _ST_AsKML(2, geometry, precision)
>> I noticed that this is not in the online documentation [1]. Any ideas
>> on what prompted this change, or when it will be documented? Could I
>> be looking in the wrong places?
>> Cheers,
>> Dylan
> Hi Dylan,
> In newer versions of PostGIS we standardised on the form of the ST_As*ML()
> functions so that they are all of the form (version, geometry, precision).
> However, for older functions that didn't have the version parameter by
> default, there should be a PL/PGSQL wrapper function that acts as a
> compatibility layer.
> So as Regina suggested, it sounds to me as if something went wrong as part
> of a database upgrade from an earlier PostGIS version so that the wrapper
> function is not present in your new database.
> HTH,
> Mark.
Thanks for the tips Mark. The funny thing about this specific problem
is that it occurred with a fresh install from the PostGIS website. I
was only able to 'discover' _STAsKML() but grepping through
lwpostgis.sql
Ideas?
Dylan
