[postgis-users] Re: postgis-users Digest, Vol 73, Issue 21
Abram Gillespie
abe.gillespie.lists at gmail.com
Tue Nov 25 10:10:03 PST 2008
Hello John,
I usually like to stay neutral about zigGIS conversations and let the
community speak for itself. But since you're not getting a response
I'll say this: we have a demo. Why not give it a try yourself?
http://pub.obtusesoft.com/demo.aspx
Happy Thanksgiving.
Ciao!
On Sat, Nov 22, 2008 at 3:17 PM, John Zhang <johnzhang06 at gmail.com> wrote:
> Hi Eric,
> First of all, I would like to express thanks to all the responders. Due to
> our own user base of ArcGIS, it would be not easy change ArcGIS as the
> client to others, such as uDig, Manifold. So the middle man between ArcGIS
> and PostGIS is important for decision makers. We can not afford to buy SDE
> for the small business to connect ArcGIS to PosGIS.
> I also read something about zigGIS which claims to be PostGIS extension to
> ArgGIS. I have not had time trying it out yet. If you buy the license and
> try it out, I believe the community would appreciate a lot if you, Eric,
> share your experience with us. If zigGIS works fine as an extension to
> ArcGIS, that would be great to the large ArcGIS user base.
> Could anyone with zigGIS experience share your experience?
> Thanks
> John
>> Date: Fri, 21 Nov 2008 06:02:00 -0500
>> From: "Randall, Eric" <ERandall at eriecountygov.org>
>> Subject: RE: [postgis-users] how to connect ArcGIS 9.3 to
>> PostgiswithoutArcSDE ?
>> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
>> Message-ID:
>> <CD32AE6ACD828644B29601ADC966FDCB01B4AB8D at ex1.eriecountygov.local>
>> Content-Type: text/plain; charset="iso-8859-1"
>> What about the ZigGIS extension? http://pub.obtusesoft.com/
>> I don't have it yet but am planning on acquiring a couple liceses in order
>> to
>> use PostGIS data from the ArcGIS Desktop. That might be the lowest cost
>> solution
>> without changing clients.
>> -Eric
> postgis-users mailing list
