[postgis-users] geom null
Paul Ramsey
pramsey at cleverelephant.ca
Fri Nov 28 09:05:50 PST 2008
It's very much a client side issue, not a PostGIS issue. Ask the
QGIS/gvSIG/uDig folks how they support your use case.
P.
On Fri, Nov 28, 2008 at 8:12 AM, ju <julien.guilloux at espaces-naturels.fr> wrote:
> thanks but my table contains data for 1500 geographical place we are going
> to digitize
> some will be point, other line and other polygon
> so i can not make a false object and then modify it.
> Chris Hermansen a écrit :
>> Interesting question. What if, instead of null, you put in a simple piece
>> of geometry that you can modify? (a point or a line or a 3-point linestring
>> or a rectangle)?
>> ju wrote:
>>> Hi list,
>>> i have imported a table in postgres with only data fields.
>>> i add a geom field and i would like to digize object, for example with
>>> Qgis or GV sig.
>>> my table record is visible in qgis or gv sig but impossible to
>>> digitize...
>>> i think the trouble is not qgis or gvsig but a trouble of concept : is it
>>> possible to digitize a geom in postgis table if the record ( with geom null)
>>> allready exist ?
>>> thanks for helping,
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Julien-Pierre Guilloux
> Service scientifique - Géomatique
> Parc National des Ecrins
> Domaine de Charance
> 05 000 GAP
> tél : 04.92.40.20.10
> fax : 04.92.52.38.34
