[postgis-users]Re: Installing PostGIS on Mac OS X
Maurits Diephuis
m.diephuis at student.utwente.nl
Thu Oct 9 07:59:36 PDT 2008
William Kyngesburye wrote:
> On Oct 8, 2008, at 9:40 AM, Maurits Diephuis wrote:
>> Hi,
>> I'm trying to install postGIS on Mac OS X (Leopard 10.5.5 on intel)
>> I've downloaded to following binaries:
>> http://www.kyngchaos.com/files/software/unixport/PostgreSQL-8.3.3-1.dmg
>> http://www.kyngchaos.com/files/software/unixport/PostGIS-1.3.3-1a.dmg
>> And the GEOS 3 and PROJ 3 frameworks from the same site.
>> I have Postgre up and running with a database called SDM,
>> I then ran this command:
>> sudo su - postgres -c '/usr/local/pgsql/bin/createlang -U postgres
>> plpgsql SDM'
>> Which works as far as I can see, but then PostGIS gives this error:
>> $ sudo su - postgres -c '/usr/local/pgsql/bin/psql -d SDM -f
>> /usr/local/pgsql/share/lwpostgis.sql'
>> Password:
>> BEGIN
>> psql:/usr/local/pgsql/share/lwpostgis.sql:44: NOTICE: type
>> "histogram2d" is not yet defined
>> DETAIL: Creating a shell type definition.
>> psql:/usr/local/pgsql/share/lwpostgis.sql:44: ERROR: could not access
>> file "$libdir/liblwgeom": No such file or directory
> This comes up occassionally on the list, and seems to be a problem with
> configuring the compilation (shouldn't be in this case) or
> LD_LIBRARY_PATHS at runtime (a linux problem, doesn't apply to OSX).
> Maybe the logs have something helpful? Open Console.app and see if
> there is anything in "All Messages" first. Hopefully there will be an
> expanded error message about that $libdir - what did Postgres actually try.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> "Time is an illusion - lunchtime doubly so."
> - Ford Prefect
hi,
I couldn't find anything in the logs, but I did manage to get everything
working today.
I basically replaced all $libdir occurrences with the actual path.
tnx !
Maurits
Maurits Diephuis
053 4351014 - 06 4301 7034
www.utfoto.nl
