[postgis-users] ST_Union (8.4) and TopologyException
Paul Ramsey
pramsey at cleverelephant.ca
Sat Aug 8 07:14:41 PDT 2009
It's odd for union to return no result.
The "high speed" union can only kick in when run against collections
consisting entirely of polygons. If you have a non-polygon, you'll get
the old behavior. You might even get the old behavior if you have a
null in there, that's a case I'm not sure of.
P.
On Fri, Aug 7, 2009 at 10:37 PM, Simon
Greener<simon at spatialdbadvisor.com> wrote:
> To those who asked for a test case.
> I prepared and sent a test case to Regina to ensure it was a good test set before sending it on to the discussion list.
> Regina tested it and reported to me that:
> "I tested this against GEOS 3.2 SVN and it worked. Against GEOS 3.1.1 it doesn't."
> I was running GEOS 3.1.1 as part of the standard PostGIS 1.4 on PostgreSQL 8.4 combo.
> Regina provided me with the compiled GEOS 3.2 libraries:
> SELECT postgis_full_version();
> "POSTGIS="1.4.0" GEOS="3.2.0-CAPI-1.6.0" PROJ="Rel. 4.6.1, 21 August 2008" USE_STATS"
> I can confirm that my data is now successfully processed by PostGIS's ST_Union though it isn't all that fast:
> "Query returned successfully with no result in 5011922 ms." = 1hr 23min which is pretty slow.
> Any idea why?
> regards
> Simon
> SpatialDB Advice and Design, Solutions Architecture and Programming,
> Oracle Database 10g Administrator Certified Associate; Oracle Database 10g SQL Certified Professional
> Oracle Spatial, SQL Server, PostGIS, MySQL, ArcSDE, Manifold GIS, FME, Radius Topology and Studio Specialist.
> 39 Cliff View Drive, Allens Rivulet, 7150, Tasmania, Australia.
> Website: www.spatialdbadvisor.com
> Email: simon at spatialdbadvisor.com
> Voice: +61 362 396397
> Mobile: +61 418 396391
> Skype: sggreener
> Longitude: 147.20515 (147° 12' 18" E)
> Latitude: -43.01530 (43° 00' 55" S)
> NAC:W80CK 7SWP3
> postgis-users mailing list
