[postgis-users] river network
Kevin Neufeld
kneufeld at refractions.net
Wed Feb 18 22:52:46 PST 2009
Hi Surya,
No, I didn't say it should be, only that I assumed it was. It only
matters in the query and how you look at things. If you are digitized
in an upstream direction, then the stream mouth will be the startpoint
of the linestring and the headwaters the endpoint ... so you would
reverse the logic in your query (find all streams whose startpoint (or
mouth) touches the endpoint (or headwater) of your token stream).
SELECT b.*
FROM streams a, streams b
WHERE a.stream_id = 1 -- your specified segment
AND a.the_geom && b.the_geom
AND ST_Distance(
ST_EndPoint(a.the_geom),
ST_StartPoint(b.the_geom)
) = 0;
Cheers,
Kevin
storma-ipb at indo.net.id wrote:
> You said that the river should be digitized in downstraem
> direction (mimicing the river flow??). Is there any different
> when we digitized them in upstream direction?
> best regards,
> surya
>> -- Assuming your dataset is properly noded, directionalized
>> -- and digitized in a downstream direction, this will find
>> -- all streams that enter into stream with id = 1
>> SELECT b.*
>> AND ST_Distance(
>> ST_StartPoint(a.the_geom),
>> ST_EndPoint(b.the_geom)
>> ) = 0;
