[postgis-users] Merging Contour tables in PostGIS
Max Bott
max.d.bott at gmail.com
Wed Feb 18 23:34:03 PST 2009
Hi All,
I have 2 tables (contours1 & contours2) in my postgis database which I have
populated from shapefiles containing contours in adjacent geographic areas.
These 2 tables contain (amongst other things) the following columns
"ELEVATION" double precision,
the_geom geometry
To create my merged table covering the contours from both contours1 and
contours2 I used
SELECT a.ELEVATION,ST_LineMerge(ST_Collect(a.the_geom, b.the_geom)) AS
the_geom
INTO merged_contours
FROM
contours1 AS a,contours2 AS b
GROUP BY ELEVATION;
but that gave the result
********** Error **********
ERROR: column a.elevation does not exist
SQL state: 42703
Character: 8
Any ideas?
Cheers,
Max
View this message in context: http://www.nabble.com/Merging-Contour-tables-in-PostGIS-tp22095290p22095290.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
