[postgis-users] Re: maximum distance between a POINT and POLYGON
My Pid
mamat750 at gmail.com
Sun Feb 22 11:59:20 PST 2009
Kevin,
Thanks a lot for your "geometry to text" advice.
It works perfectly now
Nick
Message: 30
Date: Thu, 19 Feb 2009 08:51:21 -0800
Subject: Re: [postgis-users] Re: maximum distance between a POINT and
POLYGON
To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Message-ID: <499D8E09.8000205 at refractions.net>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Try moving your query into a subquery and then taking the max distance.
Also, you can probably drop the subquery you
put as a parameter to the generate_series call. Why are you converting the
geometry to text, then back to a geometry again?
ie.
SELECT "cellID", max(dist)
FROM (
-- Your query here, but also select the cellID to group on
SELECT
cellID,
distance_spheroid(
geometry_centroid,
ST_PointN(
ExteriorRing(geometry_zone),
generate_series(1, ST_NPoints(geometry_zone))
'SPHEROID["WGS 84",6378137,298.257223563]'
) AS dist
FROM "208_1_26624_zones"
WHERE > "cellID"='1'
) AS foo
GROUP BY "cellID";
-- Kevin
My Pid wrote:
> Hello again,
> I found the generate_series function (yes i am a newbie!) and I can use
> it in order to calculate the distance between
> my centroid (geometry_centroid) and my polygon (geometry_zone) with the
> following request
> SELECT
> (distance_spheroid(geometry_
centroid,ST_AsText(ST_PointN(ExteriorRing(geometry_zone),
> generate_series(1,(SELECT npoints(geometry_zone) FROM
> "208_1_26624_zones" WHERE "cellID"='1')))), 'SPHEROID["WGS
> 84",6378137,298.257223563]')) as d FROM "208_1_26624_zones" WHERE
> "cellID"='1';
> Now I can't use the max function because of the following error:
> "set-valued function called in context that cannot accept a set"
> when I use
> SELECT
max(distance_spheroid(geometry_centroid,ST_AsText(ST_PointN(ExteriorRing(geometry_zone),
> "cellID"='1';
> any idea ?
> thanks!
> Nick
> 2009/2/18 My Pid <mamat750 at gmail.com <mailto:mamat750 at gmail.com>>
> Hello,
> I would like to know how I could get the maximum distance between a
> POINT and a POLYGON.
> (the POINT i am talking about here is in fact the ST_Centroid of the
> mentionned POLYGON)
> I looked for a function that transform my POLYGON into several POINT
> but without success.
> I am working with longitude, latitude, altitude for POINT
> It is really the max distance that I am looking for (not the minimum
> distance.)
> and "accuracy" is important to me.
> thanks in advance for your help !
> regards,
> Nick
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090222/ba6e9718/attachment.html>
