[postgis-users] Error installing PostGIS 1.3.5 on Windows Server 2003 Enterprise R2
Frode Wiseth Jørgensen
frodewj at gmail.com
Fri Mar 13 07:50:40 PDT 2009
According to this..
http://www.nabble.com/RE%3A-PostGIS-installation-error-to22345516.html#a22345859
..choosing "Ignore" is harmless.
Straatvark wrote:
> I have the same problem.
> I'm sure i should be worried when i select "ignore", but i dont know of
> what...
> Frode Wiseth Jørgensen wrote:
>> Hi,
>> I'm having the same problem.
>> Did you find a solution?
>> Regards
>> Frode
>> Gianfranco Mangiarano wrote:
>>> Sure, I'm runnin as Administrator.
>>>>> Hi Leo,
>>>>> I used two methods:
>>>>> 1) Install Postgis through the stack builder module
>>>>> 2) Download and install PostGIS using the offline installer
>>>> Are you running as an Administrator? You'll need to do this in order
>>>> to make sure you have permissions to write to the PostgreSQL
>>>> installation directory.
>>>> ATB,
>>>> Mark.
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
View this message in context: http://www.nabble.com/Error-installing-PostGIS-1.3.5-on-Windows-Server-2003-Enterprise-R2-tp21917830p22498033.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
