[postgis-users] Can I build an index oncombinednon-spatial&spatial columns?
Kemal Bayram kemal at cins.co.uk
Wed Mar 18 07:35:45 PDT 2009
Well spatial indicies are not actually accurate because they use 32bit
floating point and work on bounding boxes, that is one assumption I
mistakenly made myself (should have RTFM properly :) So it makes sense that
you can not have a compound index.
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of M.A. (Thijs) van den Berg
> Sent: 18 March 2009 15:16
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Can I build an index
> I thinks you're right about the 'too many indices' , I'm
> worried about that too. I'll have to do some test's now to
> see what would work.
> Thanks!
> ..anyway, one thing I've learned is that there are no
> compound spatial/ non-spatial indices possibilities.
> On Mar 18, 2009, at 1:43 PM, Kemal Bayram wrote:
> > For what you want to do I don't think partial indexs are the the
> > solution as you would have too many indicies.  You don't want the
> > query taking more time going through the metadata then the actual
> > query.
> > Postgres will use a separate index you have on building
> type, infact
> > if you look at EXPLAIN the best case costs are lower with
> an index on
> > building_type than on a partial index.  And like I said if
> performance
> > of this query is critical you can cluster on the building_type.
> > You really need to play around with your queries to see
> what is best.
> Behalf Of
> >> Sent: 18 March 2009 14:08
> >> Subject: Re: [postgis-users] Can I build an index on
> >> Thanks, that's true. I think the performance benefit with be good
> >> because I have approx 10.000 building_type's (although,
> that's a lot
> >> of indices to choose between). A typical distance query for a
> >> specific building_type will result in 10-100 matches. Not using
> >> partial indexing will thus result in appox 500.000  rows for each
> >> query (all building types), which I would then have to filter on
> >> building_type, reducing the resultset with a factor 10.000
> >> Giving it some more thought, I think splitting the building table
> >> into individual building_type tables (and attaching
> spatial indices
> >> to
> >> those) might be the best solution.
> >> From a technical point, I think the postgresql CREATE INDEX should
> >> support multiple USING to allow for mixed patial / non-spatial
> >> indices, something like this:
> >> CREATE INDEX blabla ON buildings (USING HASH(building_type), USING
> >> GIST(the_geom))
> >> internally that could be rewritten as CREATE INDEX
> blabla_hash_value1
> >> ON buildings USING
> >> GIST(the_geom) WHERE hash(building_type)=value1 CREATE INDEX
> >> blabla_hash_value2 ON buildings USING GIST(the_geom) WHERE
> >> hash(building_type)=value2 ..
> >> On Mar 18, 2009, at 12:43 PM, Kemal Bayram wrote:
> >>> Well according to EXPLAIN a partial index is taken into
> >> account, how
> >>> much of a performance benefit you gain ultimately depends
> >> on how many
> >>> records lie within your average distance.
> >>> If your data set is relatively static you may also want
> to consider
> >>> clustering your table too.
> >> Behalf Of
> >>>> Sent: 18 March 2009 13:00
> >>>> Subject: Re: [postgis-users] Can I build an index on combined
> >>>> Thanks :)
> >>>> Does PostGIS support partial indices?
> http://www.postgresql.org/docs/8.3/interactive/indexes-partial.html
> >>>> If so.. I could do something like this:
> >>>> CREATE INDEX building_type_spindx_school ON buildings USING
> >>>> GIST(the_geom) WHERE building_type='School';
> >>>> CREATE INDEX building_type_spindx_bar ON buildings USING
> >>>> GIST(the_geom) WHERE building_type='Bar';
> >>>> Yet another option would be to partition the buildings
> table into
> >>>> child tables per building_type (ie have child table
> containing all
> >>>> the schools, another child table having all the bars), and have
> >>>> individua spatial indices on the child tables. Is that an option?
> >>>> On Mar 18, 2009, at 11:36 AM, Kemal Bayram wrote:
> >>>>> I don't know about combining indexes but you want to
> >>>> include a spatial
> >>>>> operator such as && in addition to Distance so that you
> can take
> >>>>> advantage of an index on "the_geom".
> >>>> Behalf Of
> >>>>>> Sent: 18 March 2009 11:57
> >>>>>> To: postgis-users at postgis.refractions.net
> >>>>>> Subject: [postgis-users] Can I build an index on combined
> >>>> non-spatial
> >>>>>> &spatial columns?
> >>>>>> Suppose I want to speedup the following  type of
> queries with an
> >>>>>> index:
> >>>>>> SELECT the_geom, building_name
> >>>>>> FROM buildings
> >>>>>> WHERE Distance(the_geom, 'POINT(100312 102312)') < 5000  AND
> >>>>>> building_type = 'School'
> >>>>>> Is that possible, and if not, why not? My current option
> >>>> is to write
> >>>>>> my own index storage in C++, using a hashmap to filter
> >>>> building_type,
> >>>>>> and build separate spatial indices for each building type.
> >>>> Can I do
> >>>>>> something similar in postgresql?
> >>>>>> Would my only option be to split the building_types into
> >> separate
> >>>>>> tables?
> >>>>>> _______________________________________________
> >>>>>> postgis-users mailing list
> >>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
